Hi
i am trying to get Zigbee2MQTT to work with Sonoff Plus
o had the sonoff plus working on the system with ZHA, then completely deleted ZHA and all it components from my system and did a full reboot
I have installed the Zigbee2MQTT with following config
d
ata_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
server: mqtt://192.168.22.15:1883
serial:
port: >-
/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231218183756-if00
adaptor: ezsp
I keep getting error “Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)”
I also tried the standard /dev/ttyACM0 port but with the same result
the installation is on homeassistant OS
any idea what else I can try to get it to work ?
