I bought three of the above smartplugs. They have firmware revisions 1.5, 1.5 and 1.6 . The manual is at blob:https://homeassistant.localdomain:8123/db34864a-b72e-46b8-b2df-f401710e2481 .
This is an older device that supports S0 encryption, not S2. There is no DSK or Smartstart code.
Last week, I was able to add one of the three smartplugs, with rev 1.5, securely.
Today, I tried the other two, and I am not having any luck with the security. It works fine if I include in non-secure mode with the triple tap of the button.
If I set Z-Wave JS UI in default mode + prefer encryption, and hold the button for over 3 seconds, ZUI reports that the inclusion failed after 30 seconds. However, the device thinks inclusion actually succeeded. Its LED no longer blinks, indicating it has been successfully included in a Z-Wave network. ZUI does not show the device in the list of nodes, though. But after restarting the add-on, it does show it. Unfortunately, without security.
I have tried repeating the inclusion process using the “S0 encryption” inclusion option, but I did not get any better results. I’m banging my head against the wall on this one. I don’t know why the first smartplug worked last week and what I did differently. I was on ZUI 3.x, though, and I just upgraded to ZUI 4.0.
Here is a Z-Wave JS log of today’s many tribulations with the Hank devices.
Edit: it looks like the following error is likely the issue :
2025-03-24T07:15:09.919Z CNTRLR [Node 204] Timed out while waiting for a response from the node (ZW0201)
2025-03-24T07:15:09.920Z CNTRLR [Node 204] The node was not granted the S0 security class. Continuing intervie
w non-securely.
As I mentioned, one of the 3 smartplugs did add securely.
It is node 185. It was added on 3/21. Here is the log that has its successful S0 inclusion.
It looks like it was started with strategy “default”.
2025-03-21T17:09:30.740Z CNTRLR Starting inclusion process with strategy Default...
And then shortly after, I see :
2025-03-21T17:09:59.572Z CNTRLR [Node 185] Security S0 bootstrapping successful
I’m going to reset the 2 problematic plugs and try one more time with the “default” strategy, without checking the “force security” box.
