Can't install 2021.1.4
I just got a Pi4 8gb to move away from the VM I was using but when I try to install it I get a 500 error. I even tried the 32 bit and tried changing the DNS on my router. Is there a way to skip this update when installing and not make the install dirty? Or how often are more disk images made I may just wait until then or if I can somehow manually throw the update on my card that would be great.
Can you give us more details ? What procedure do you use to install Home assistant ? on SD card ? SSD ? When do you get a 500 error in which step or action ? Any error in the logs ?
I may have found someone having the same problem. Here is my error code:
21-01-18 17:03:12 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-homeassistant with tag 2021.1.4.
21-01-18 17:03:27 ERROR (SyncWorker_2) [supervisor.docker.interface] Can’t install homeassistant/raspberrypi4-homeassistant:2021.1.4 → 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.1.4&fromImage=homeassistant%2Fraspberrypi4-homeassistant: Internal Server Error (“Get “https://registry-1.docker.io/v2/”: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)”).
21-01-18 17:03:27 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
I finally was able to get in to change to the solution in this thread. Can't install homeassistant:2020.12.0
