I would like to install add ons but the button under Settings is missing and when pressing ‘c’ and typing ‘add’ add-ons aren’t shown.
How to fix this?
I’m using v2022.6.7
I’m using v2022.6.7
Addons are only available if you used HAOS or Supervised as your installation type.
What kind of installation are you running?
Thanks for the reply.
I installed Home Assistant via Docker on a Raspberry Pi.
Is that a problem?
Yes - Container install (Core in Docker) does not support Add-ons. That only comes with HomeAssistant OS or Supervised. If you are managing your own core install in Docker you’ll have to obtain your own containers for those services, and if you want to use Addons then you either need to use HAOS or a Supervised install.
Thank you.
