Can't install addons
I’m very new to home assistant and just installed it but came to a stop when I try to install addons
When I install an addon is shows an error
‘AddonManager.install’ blocked from execution, system is not healthy
Also I’ve tried to update but it also shows me an error
In my notifications it shows a message and says
Login attempt or request with invalid authentication from host-20.home (192.168.254.16). See the log for details.
I’m very confused on what to do next and how to fix it?
Go to settings → repairs and check does system offer you any repairs that you can do.
You can also check under repairs three dots upper right corner System information.
I’ve check and it says “There are currently no repairs available”
and what does system information says? it will point out why your system is unhealthy.
Sorry I’m new but where can I find that?
System Information
version core-2022.10.4
installation_type Home Assistant OS
dev false
hassio true
docker true
user root
virtualenv false
python_version 3.10.5
os_name Linux
os_version 5.15.61-v8
arch aarch64
timezone America/Chicago
config_dir /config
Home Assistant Cloud
logged_in false
can_reach_cert_server ok
can_reach_cloud_auth ok
can_reach_cloud ok
Home Assistant Supervisor
host_os Home Assistant OS 9.2
update_channel stable
supervisor_version supervisor-2022.09.1
agent_version 1.4.1
docker_version 20.10.17
disk_total 13.9 GB
disk_used 2.8 GB
healthy failed to load: Unhealthy
supported true
board rpi4-64
supervisor_api ok
version_api ok
installed_addons
Dashboards
dashboards 1
resources 0
mode auto-gen
Recorder
oldest_recorder_run October 16, 2022 at 6:07 PM
current_recorder_run October 16, 2022 at 1:07 PM
estimated_db_size 0.23 MiB
database_engine sqlite
database_version 3.38.5
Im sorry I dont use home assistant OS. Maybe someone who is using haos will help you with this.
Ok np Thanks
What does it say under „learn mor for your unhealthy installation
