I’m at a total loss here. After moving from .47 to .49.x no new dependencies install anymore. First I thought it was just the chromecast causing this but after upgrading to .49.1 (thinking this might solve it) also zwave (arghhh) and sysmon is not installing it’s dependencies.
I’m running pre dec 16 AIO
Below is an example of Chromecast but error details are the same for the other two dependencies.
What I tried based on searching the forum:
- Updated all packages on the PI
- Delete directories under .cache (not only the pip but also the wheels one, hope this did not break anything else)
- Trying to manually install (for example) pychromecast in the virtual environment both as HASS and as PI user. (see output as bottom of this post)
Any help really appreciated!
Logfile hass:
2017-07-27 10:02:30 ERROR (Thread-4) [homeassistant.util.package] Unable to install package pychromecast==0.8.1: Command "/srv/hass/hass_venv/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-kw_9phkh/netifaces/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-o1532zc9-record/install-record.txt --single-version-externally-managed --compile --install-headers /srv/hass/hass_venv/include/site/python3.4/netifaces --home=/tmp/tmpqkcc3t_k" failed with error code 1 in /tmp/pip-build-kw_9phkh/netifaces/
(hass_venv) pi@raspberrypi:~ $ sudo pip install pychromecast
Collecting pychromecast
Downloading PyChromecast-0.8.2-py2.py3-none-any.whl (40kB)
100% |████████████████████████████████| 40kB 1.4MB/s
Collecting protobuf>=3.0.0 (from pychromecast)
Downloading protobuf-3.3.0.tar.gz (271kB)
100% |████████████████████████████████| 276kB 830kB/s
Collecting zeroconf>=0.17.7 (from pychromecast)
Downloading zeroconf-0.19.1-py2.py3-none-any.whl
Requirement already satisfied: requests>=2.0 in /usr/local/lib/python3.4/dist-packages (from pychromecast)
Requirement already satisfied: six>=1.10.0 in /usr/local/lib/python3.4/dist-packages (from pychromecast)
Requirement already satisfied: setuptools in /usr/lib/python3/dist-packages (from protobuf>=3.0.0->pychromecast)
Collecting enum-compat (from zeroconf>=0.17.7->pychromecast)
Downloading enum-compat-0.0.2.tar.gz
Collecting netifaces!=0.10.5 (from zeroconf>=0.17.7->pychromecast)
Downloading netifaces-0.10.6.tar.gz
Installing collected packages: protobuf, enum-compat, netifaces, zeroconf, pychromecast
Running setup.py install for protobuf ... done
Running setup.py install for enum-compat ... done
Running setup.py install for netifaces ... error
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-kcqtu3e6/netifaces/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-8r1q28is-record/install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_ext
checking for getifaddrs...found.
checking for getnameinfo...found.
checking for IPv6 socket IOCTLs...not found.
checking for optional header files...netash/ash.h netatalk/at.h netax25/ax25.h neteconet/ec.h netipx/ipx.h netpacket/packet.h linux/irda.h linux/atm.h linux/llc.h linux/tipc.h linux/dn.h.
checking whether struct sockaddr has a length field...no.
checking which sockaddr_xxx structs are defined...at ax25 in in6 ipx un ash ec ll atmpvc atmsvc dn irda llc.
checking for routing socket support...no.
checking for sysctl(CTL_NET...) support...no.
checking for netlink support...yes.
will use netlink to read routing table
building 'netifaces' extension
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 -fPIC -DNETIFACES_VERSION=0.10.6 -DHAVE_GETIFADDRS=1 -DHAVE_GETNAMEINFO=1 -DHAVE_NETASH_ASH_H=1 -DHAVE_NETATALK_AT_H=1 -DHAVE_NETAX25_AX25_H=1 -DHAVE_NETECONET_EC_H=1 -DHAVE_NETIPX_IPX_H=1 -DHAVE_NETPACKET_PACKET_H=1 -DHAVE_LINUX_IRDA_H=1 -DHAVE_LINUX_ATM_H=1 -DHAVE_LINUX_LLC_H=1 -DHAVE_LINUX_TIPC_H=1 -DHAVE_LINUX_DN_H=1 -DHAVE_SOCKADDR_AT=1 -DHAVE_SOCKADDR_AX25=1 -DHAVE_SOCKADDR_IN=1 -DHAVE_SOCKADDR_IN6=1 -DHAVE_SOCKADDR_IPX=1 -DHAVE_SOCKADDR_UN=1 -DHAVE_SOCKADDR_ASH=1 -DHAVE_SOCKADDR_EC=1 -DHAVE_SOCKADDR_LL=1 -DHAVE_SOCKADDR_ATMPVC=1 -DHAVE_SOCKADDR_ATMSVC=1 -DHAVE_SOCKADDR_DN=1 -DHAVE_SOCKADDR_IRDA=1 -DHAVE_SOCKADDR_LLC=1 -DHAVE_PF_NETLINK=1 -I/usr/include/python3.4m -c netifaces.c -o build/temp.linux-armv7l-3.4/netifaces.o
netifaces.c:1:20: fatal error: Python.h: No such file or directory
#include <Python.h>
compilation terminated.
error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-kcqtu3e6/netifaces/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-8r1q28is-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-build-kcqtu3e6/netifaces/
If I do the same with PSutil (als a dependencies that does not install:
(hass_venv) pi@raspberrypi:~ $ sudo pip install psutil==5.2.2
Collecting psutil==5.2.2
Downloading psutil-5.2.2.tar.gz (348kB)
100% |████████████████████████████████| 358kB 740kB/s
Installing collected packages: psutil
Running setup.py install for psutil ... error
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-1_55n5de/psutil/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-712aidg9-record/install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
creating build/lib.linux-armv7l-3.4
creating build/lib.linux-armv7l-3.4/psutil
copying psutil/_psbsd.py -> build/lib.linux-armv7l-3.4/psutil
copying psutil/_psosx.py -> build/lib.linux-armv7l-3.4/psutil
copying psutil/__init__.py -> build/lib.linux-armv7l-3.4/psutil
copying psutil/_compat.py -> build/lib.linux-armv7l-3.4/psutil
copying psutil/_common.py -> build/lib.linux-armv7l-3.4/psutil
copying psutil/_pslinux.py -> build/lib.linux-armv7l-3.4/psutil
copying psutil/_pswindows.py -> build/lib.linux-armv7l-3.4/psutil
copying psutil/_pssunos.py -> build/lib.linux-armv7l-3.4/psutil
copying psutil/_psposix.py -> build/lib.linux-armv7l-3.4/psutil
creating build/lib.linux-armv7l-3.4/psutil/tests
copying psutil/tests/__init__.py -> build/lib.linux-armv7l-3.4/psutil/tests
copying psutil/tests/test_linux.py -> build/lib.linux-armv7l-3.4/psutil/tests
copying psutil/tests/test_misc.py -> build/lib.linux-armv7l-3.4/psutil/tests
copying psutil/tests/test_bsd.py -> build/lib.linux-armv7l-3.4/psutil/tests
copying psutil/tests/runner.py -> build/lib.linux-armv7l-3.4/psutil/tests
copying psutil/tests/test_memory_leaks.py -> build/lib.linux-armv7l-3.4/psutil/tests
copying psutil/tests/test_posix.py -> build/lib.linux-armv7l-3.4/psutil/tests
copying psutil/tests/test_windows.py -> build/lib.linux-armv7l-3.4/psutil/tests
copying psutil/tests/test_osx.py -> build/lib.linux-armv7l-3.4/psutil/tests
copying psutil/tests/test_process.py -> build/lib.linux-armv7l-3.4/psutil/tests
copying psutil/tests/test_sunos.py -> build/lib.linux-armv7l-3.4/psutil/tests
copying psutil/tests/test_system.py -> build/lib.linux-armv7l-3.4/psutil/tests
running build_ext
building 'psutil._psutil_linux' extension
creating build/temp.linux-armv7l-3.4
creating build/temp.linux-armv7l-3.4/psutil
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 -fPIC -DPSUTIL_POSIX=1 -DPSUTIL_VERSION=522 -DPSUTIL_LINUX=1 -I/usr/include/python3.4m -c psutil/_psutil_linux.c -o build/temp.linux-armv7l-3.4/psutil/_psutil_linux.o
psutil/_psutil_linux.c:12:20: fatal error: Python.h: No such file or directory
#include <Python.h>
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-1_55n5de/psutil/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-712aidg9-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-build-1_55n5de/psutil/
