Been trying to work with docker-compose and I have followed soo many steps on getting it install and just running the docker-compose --version and nothing!!!
Here is my output. I have also tried these other commands here
pi@hasspi:~ $ sudo pip install docker-compose
DEPRECATION: Python 2.7 will reach the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 won’t be maintained after that date. A future version of pip will drop support for Python 2.7.
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting docker-compose
Using cached https://files.pythonhosted.org/packages/51/56/5745e66b33846e92a8814466c163f165a26fadad8b33afe381e8b6c3f652/docker_compose-1.24.0-py2.py3-none-any.whl
Requirement already satisfied: docker[ssh]<4.0,>=3.7.0 in /usr/local/lib/python2.7/dist-packages (from docker-compose) (3.7.0)
Requirement already satisfied: backports.ssl-match-hostname>=3.5; python_version < “3.5” in /usr/local/lib/python2.7/dist-packages (from docker-compose) (3.7.0.1)
Requirement already satisfied: websocket-client<1.0,>=0.32.0 in /usr/local/lib/python2.7/dist-packages (from docker-compose) (0.54.0)
Requirement already satisfied: ipaddress>=1.0.16; python_version < “3.3” in /usr/lib/python2.7/dist-packages (from docker-compose) (1.0.17)
Requirement already satisfied: PyYAML<4.3,>=3.10 in /usr/local/lib/python2.7/dist-packages (from docker-compose) (3.13)
Requirement already satisfied: dockerpty<0.5,>=0.4.1 in /usr/local/lib/python2.7/dist-packages (from docker-compose) (0.4.1)
Requirement already satisfied: texttable<0.10,>=0.9.0 in /usr/local/lib/python2.7/dist-packages (from docker-compose) (0.9.1)
Requirement already satisfied: enum34<2,>=1.0.4; python_version < “3.4” in /usr/lib/python2.7/dist-packages (from docker-compose) (1.1.6)
Requirement already satisfied: requests!=2.11.0,!=2.12.2,!=2.18.0,<2.21,>=2.6.1 in /usr/lib/python2.7/dist-packages (from docker-compose) (2.12.4)
Requirement already satisfied: six<2,>=1.3.0 in /usr/lib/python2.7/dist-packages (from docker-compose) (1.10.0)
Requirement already satisfied: jsonschema<3,>=2.5.1 in /usr/local/lib/python2.7/dist-packages (from docker-compose) (2.6.0)
Requirement already satisfied: docopt<0.7,>=0.6.1 in /usr/local/lib/python2.7/dist-packages (from docker-compose) (0.6.2)
Requirement already satisfied: cached-property<2,>=1.2.0 in /usr/local/lib/python2.7/dist-packages (from docker-compose) (1.5.1)
Requirement already satisfied: docker-pycreds>=0.4.0 in /usr/local/lib/python2.7/dist-packages (from docker[ssh]<4.0,>=3.7.0->docker-compose) (0.4.0)
Collecting paramiko>=2.4.2; extra == “ssh” (from docker[ssh]<4.0,>=3.7.0->docker-compose)
Using cached https://files.pythonhosted.org/packages/cf/ae/94e70d49044ccc234bfdba20114fa947d7ba6eb68a2e452d89b920e62227/paramiko-2.4.2-py2.py3-none-any.whl
Requirement already satisfied: functools32; python_version == “2.7” in /usr/local/lib/python2.7/dist-packages (from jsonschema<3,>=2.5.1->docker-compose) (3.2.3.post2)
Collecting pynacl>=1.0.1 (from paramiko>=2.4.2; extra == “ssh”->docker[ssh]<4.0,>=3.7.0->docker-compose)
Using cached https://files.pythonhosted.org/packages/61/ab/2ac6dea8489fa713e2b4c6c5b549cc962dd4a842b5998d9e80cf8440b7cd/PyNaCl-1.3.0.tar.gz
Installing build dependencies … error
ERROR: Complete output from command /usr/bin/python /usr/local/lib/python2.7/dist-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-PWg5ef/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple – setuptools wheel ‘cffi>=1.4.1; python_implementation != ‘"’"‘PyPy’"’"’’:
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple, https://www.piwheels.org/simple
Collecting setuptools
Using cached https://files.pythonhosted.org/packages/ec/51/f45cea425fd5cb0b0380f5b0f048ebc1da5b417e48d304838c02d6288a1e/setuptools-41.0.1-py2.py3-none-any.whl
Collecting wheel
Using cached https://files.pythonhosted.org/packages/bb/10/44230dd6bf3563b8f227dbf344c908d412ad2ff48066476672f3a72e174e/wheel-0.33.4-py2.py3-none-any.whl
Collecting cffi>=1.4.1
Using cached https://files.pythonhosted.org/packages/93/1a/ab8c62b5838722f29f3daffcc8d4bd61844aa9b5f437341cc890ceee483b/cffi-1.12.3.tar.gz
Collecting pycparser (from cffi>=1.4.1)
Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.19-py2.py3-none-any.whl
Building wheels for collected packages: cffi
Building wheel for cffi (setup.py): started
Building wheel for cffi (setup.py): finished with status ‘error’
ERROR: Complete output from command /usr/bin/python -u -c ‘import setuptools, tokenize;file=’"’"’/tmp/pip-install-0DesQY/cffi/setup.py’"’"’;f=getattr(tokenize, ‘"’"‘open’"’"’, open)(file);code=f.read().replace(’"’"’\r\n’"’"’, ‘"’"’\n’"’"’);f.close();exec(compile(code, file, ‘"’"‘exec’"’"’))’ bdist_wheel -d /tmp/pip-wheel-sOnO3j --python-tag cp27:
ERROR: Package libffi was not found in the pkg-config search path.
Perhaps you should add the directory containing libffi.pc' to the PKG_CONFIG_PATH environment variable No package 'libffi' found Package libffi was not found in the pkg-config search path. Perhaps you should add the directory containing libffi.pc’
No package ‘libffi’ found
Perhaps you should add the directory containing libffi.pc' to the PKG_CONFIG_PATH environment variable No package 'libffi' found running bdist_wheel running build running build_py creating build creating build/lib.linux-armv7l-2.7 creating build/lib.linux-armv7l-2.7/cffi copying cffi/setuptools_ext.py -> build/lib.linux-armv7l-2.7/cffi copying cffi/pkgconfig.py -> build/lib.linux-armv7l-2.7/cffi copying cffi/cparser.py -> build/lib.linux-armv7l-2.7/cffi copying cffi/__init__.py -> build/lib.linux-armv7l-2.7/cffi copying cffi/vengine_gen.py -> build/lib.linux-armv7l-2.7/cffi copying cffi/recompiler.py -> build/lib.linux-armv7l-2.7/cffi copying cffi/verifier.py -> build/lib.linux-armv7l-2.7/cffi copying cffi/api.py -> build/lib.linux-armv7l-2.7/cffi copying cffi/ffiplatform.py -> build/lib.linux-armv7l-2.7/cffi copying cffi/cffi_opcode.py -> build/lib.linux-armv7l-2.7/cffi copying cffi/backend_ctypes.py -> build/lib.linux-armv7l-2.7/cffi copying cffi/commontypes.py -> build/lib.linux-armv7l-2.7/cffi copying cffi/model.py -> build/lib.linux-armv7l-2.7/cffi copying cffi/error.py -> build/lib.linux-armv7l-2.7/cffi copying cffi/vengine_cpy.py -> build/lib.linux-armv7l-2.7/cffi copying cffi/lock.py -> build/lib.linux-armv7l-2.7/cffi copying cffi/_cffi_include.h -> build/lib.linux-armv7l-2.7/cffi copying cffi/parse_c_type.h -> build/lib.linux-armv7l-2.7/cffi copying cffi/_embedding.h -> build/lib.linux-armv7l-2.7/cffi copying cffi/_cffi_errors.h -> build/lib.linux-armv7l-2.7/cffi running build_ext building '_cffi_backend' extension creating build/temp.linux-armv7l-2.7 creating build/temp.linux-armv7l-2.7/c arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-Ub3vap/python2.7-2.7.13=. -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/ffi -I/usr/include/libffi -I/usr/include/python2.7 -c c/_cffi_backend.c -o build/temp.linux-armv7l-2.7/c/_cffi_backend.o c/_cffi_backend.c:15:17: fatal error: ffi.h: No such file or directory #include <ffi.h> ^ compilation terminated. error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1 ---------------------------------------- ERROR: Failed building wheel for cffi Running setup.py clean for cffi Failed to build cffi Installing collected packages: setuptools, wheel, pycparser, cffi Running setup.py install for cffi: started Running setup.py install for cffi: finished with status 'error' ERROR: Complete output from command /usr/bin/python -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-0DesQY/cffi/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-ttCrs9/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-PWg5ef/overlay --compile: ERROR: Package libffi was not found in the pkg-config search path. Perhaps you should add the directory containing libffi.pc’
running install
running build
running build_py
creating build
copying cffi/init.py -> build/lib.linux-armv7l-2.7/cffi
running build_ext
building ‘_cffi_backend’ extension
error: command ‘arm-linux-gnueabihf-gcc’ failed with exit status 1
ERROR: Command “/usr/bin/python -u -c ‘import setuptools, tokenize;file=’”’"’/tmp/pip-install-0DesQY/cffi/setup.py’"’"’;f=getattr(tokenize, ‘"’"‘open’"’"’, open)(file);code=f.read().replace(’"’"’\r\n’"’"’, ‘"’"’\n’"’"’);f.close();exec(compile(code, file, ‘"’"‘exec’"’"’))’ install --record /tmp/pip-record-ttCrs9/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-PWg5ef/overlay --compile" failed with error code 1 in /tmp/pip-install-0DesQY/cffi/
As much as we try to be helpful, this is a forum to support Home-Assistant.
You probably should raise this with docker-compose themselves (https://github.com/docker/compose/issues)
