Please have a look here > https://www.dailymotion.com/video/x8cidmz
The repository https://github.com/esphome/home-assistant-addon is already in the store.
Can you please help me figure out what’s wrong and how to fix it?
Follow official documentation instead of outdated videos Getting Started with ESPHome and Home Assistant — ESPHome
Hi @vincen
Following the documentation you linked to the letter:
So I click on the “My ADD-ON” button and the browser opens HA’s log in page:
I hit “OPEN LINK” and HA’s login page appears:
I enter my credentials and the following happens:
Any ideas?
Ok, I figured it out. For anyone else who likes to follow guides to the letter, here’s what worked for me:
For clarity, the instructions here under the paragraph “Installing ESPHome Dashboard” say:
The ESPHome Dashboard can be installed as a Home Assistant add-on, which you can find in the add-on store in the Supervisor panel. Open it using the following button then click on INSTALL:
The way the last sentence is written, and especially with the “:” after the word INSTALL, may make one expect to see a button under the paragraph.
The last sentence should instead read:
The ESPHome Dashboard can be installed as a Home Assistant add-on, which you can find in the add-on store in the Supervisor panel. Search for the Add on and then install it.
@vincen thank you for your guidance
Very good point and may I suggest you to put a request to change that text so no one else is confused by it ? Link to update it is on website
