Can't install eWeLink add-on - failed to install
issue: can’t install eWeLink addon via official repository
hw: raspberry pi 4 B
sw: home assistant OS image 6.5 64bit
in the past days i successfully added eWeLink official addon and it worked good.
then because I needed to change type of installation (from supervised on a Raspbian to a Home Assistant native image) and restored backup. It didn’t worked.
then tried to uninstall and install again:
got installation error
Failed to install add-on
The command '/bin/sh -c yarn --production' returned a non-zero code: 1
Sure I messed up something i started again with a fresh install.
added repository
selected eWeLink addon
install
again same error.
so started thinking it’s something else as installation is superfresh.
maybe related to 64bit version?
edit: tried another fresh install of 32bit image, no change. Seems an issue on specific version of eWeLink trying to install (1.2.2)
Same problem here. Home Assistant Blue
Same problem for me also.
Same issue here.
It seems here is the solution: eWeLink Smart Home 1.2.2 upgrade failing - #9 by Platorello
after multiple tries and fails it got installed. now working flawlessly.
done backup :smiley:
