Can't install HA OS
I’m trying to do a fresh install on a new sd card
I use Balena Etcher with direct URL to the image (for example https://github.com/home-assistant/operating-system/releases/download/9.0/haos_rpi3-64-9.0.img.xz).
After finishing flashing the sd card, macOS says it’s not readable, not even the boot partition (which is not the case instead If I try to flash a normal RPi OS image).
This is what I see on Disk Utility on macOS:
Schermata 2022-09-20 alle 00.17.56
so no boot partition, no Linux partition
what’s going wrong?
Can’t help with Mac stuff. But try the raspberry pi imager, it has HAOS under “other sepcific-purpose os”
Thanks I’ll try.
Even though with the same software Balena Etcher (which by the way is the one suggested in other tutorials) I can flash without problems the image of RPi OS, while I get this error with the HA OS image
this is the result I obtain, from the diskutil list command:
/dev/disk7 (external, physical):
   #:                       TYPE NAME                    SIZE       IDENTIFIER
   0:      GUID_partition_scheme                        *62.2 GB    disk7
   1:         Microsoft Reserved ⁨⁩                        33.6 MB    disk7s1
   2:           Linux Filesystem ⁨⁩                        25.2 MB    disk7s2
   3:           Linux Filesystem ⁨⁩                        268.4 MB   disk7s3
   4:           Linux Filesystem ⁨⁩                        25.2 MB    disk7s4
   5:           Linux Filesystem ⁨⁩                        268.4 MB   disk7s5
   6:           Linux Filesystem ⁨⁩                        8.4 MB     disk7s6
   7:           Linux Filesystem ⁨⁩                        100.7 MB   disk7s7
   8:           Linux Filesystem ⁨⁩                        1.3 GB     disk7s8
