Hi All, I’m new to this forum and also to Home assistant.
I followed method 2 as described here:
and had no problems in installing HAOS on a HP Prodesk 400 G5 Mini i5-9500T, a couple of weeks ago.
Today, I got my hands on a HP Prodesk 600 G6 Mini i5-10500T, and I thought it would be better to use this machine for HAOS, so I followed the same process as above, and when I went to start the pc up, it would hang after a bout a page of scripts, and just wait and wait.,
I thought hmm, thats no good, so I tried to do a bit of troubleshooting. I pulled out the ssd out of the G6, and placed it in the older G5, and it booted no problem. I did the same with the working HAOS from the older G5 pc, and placed the ssd in the newer G6 mini, and the same thing happened - it would stop after about a page of scripting (mind you the script wasnt the same as the one when HAOS would boot successfully).
The only thing I could attribute this issue to is probably having something to do with the secure boot in the BIOS. I noticed that the BIOS in the G6 is slightly different in the newer machine, and only gives a tick option to select or deselect the secure boot option, however, unlike the older G5 mini, when you deselect secure boot, it also gives an option enable or disable legacy boot options. I don’t know if this has anything to do with it.
I was wondering if anyone else has had this issue, and what they’ve done to resolve it. Or if anyone else can chime in with a suggestion, then that would be great, as I’ve just spent the last couples of hours trying to troubleshoot this issue without any success.
Thanks in advance for your help.
