Can't install homeassistant:2020.12.0
Glad it worked. I was banging my head since couple days because I could not find any solution to upgrade. Than figure out this magic.
Not sure why its not saving but its should not matter as long as you assign this dhcp ip to this machine in router settings than it won’t change in future.
This solution worked perfect for me. Thanks!
This did not work for my 4.2 VM … it boots into UEFI screen and nothing.
Cannot start and get to UI…
Where can I find downgrade versions?
I also had similar problem by downloading appdaemon. For me adding setting static ip and 8.8.8.8 to the dns solved the problem.
I have the same Problem here. I’ve tried installing 5.9 5.8 and 4.20 as an Virtualbox VM on two different hosts. I have tried disabling pi-hole.
The Log for 5.9:
logs from initial boot with a fresh hassos_ova-5.9.vdi http://192.168.11.198:8123/observer/logs
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[19:40:50] INFO: Update udev information
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[19:40:51] INFO: Starting local supervisor watchdog...
20-12-23 19:40:52 INFO (MainThread) [__main__] Initializing Supervisor setup
20-12-23 19:40:52 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
20-12-23 19:40:52 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
20-12-23 19:40:52 WARNING (MainThread) [supervisor.utils.dt] Can't fetch freegeoip data: Cannot connect to host ip-api.com:80 ssl:default [Connect call failed ('0.0.0.0', 80)]
20-12-23 19:40:52 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
20-12-23 19:40:52 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/amd64-hassio-supervisor with version 2020.12.7
20-12-23 19:40:52 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
20-12-23 19:40:53 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
20-12-23 19:40:53 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
20-12-23 19:40:53 INFO (MainThread) [__main__] Setting up Supervisor
20-12-23 19:40:53 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
20-12-23 19:40:53 INFO (MainThread) [supervisor.host.info] Updating local host information
20-12-23 19:40:53 INFO (MainThread) [supervisor.host.services] Updating service information
20-12-23 19:40:53 INFO (MainThread) [supervisor.host.network] Updating local network information
20-12-23 19:40:53 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
20-12-23 19:40:53 INFO (MainThread) [supervisor.host] Host information reload completed
20-12-23 19:40:53 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
20-12-23 19:40:53 INFO (MainThread) [supervisor.host.services] Reloading local service hassos-apparmor.service
20-12-23 19:40:53 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/amd64-hassio-dns versions: ['2020.11.0']
20-12-23 19:40:53 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/amd64-hassio-dns with version 2020.11.0
20-12-23 19:40:53 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
20-12-23 19:40:54 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS homeassistant/amd64-hassio-dns with version 2020.11.0 - 172.30.32.3
20-12-23 19:40:54 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
20-12-23 19:40:54 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/amd64-hassio-audio versions: ['17']
20-12-23 19:40:54 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/amd64-hassio-audio with version 17
20-12-23 19:40:54 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
20-12-23 19:40:54 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio homeassistant/amd64-hassio-audio with version 17 - 172.30.32.4
20-12-23 19:40:54 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/amd64-hassio-cli versions: ['2020.11.1']
20-12-23 19:40:54 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/amd64-hassio-cli with version 2020.11.1
20-12-23 19:40:54 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
20-12-23 19:40:55 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI homeassistant/amd64-hassio-cli with version 2020.11.1 - 172.30.32.5
20-12-23 19:40:55 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/amd64-hassio-observer versions: ['2020.10.1']
20-12-23 19:40:55 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/amd64-hassio-observer with version 2020.10.1
20-12-23 19:40:55 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
20-12-23 19:40:55 INFO (SyncWorker_0) [supervisor.docker.observer] Starting Observer homeassistant/amd64-hassio-observer with version 2020.10.1 - 172.30.32.6
20-12-23 19:40:55 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/amd64-hassio-multicast versions: ['3']
20-12-23 19:40:55 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/amd64-hassio-multicast with version 3
20-12-23 19:40:55 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
20-12-23 19:40:55 INFO (SyncWorker_0) [supervisor.docker.multicast] Starting Multicast homeassistant/amd64-hassio-multicast with version 3 - Host
20-12-23 19:40:55 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
20-12-23 19:40:59 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
20-12-23 19:40:59 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/qemux86-64-homeassistant versions: ['landingpage']
20-12-23 19:40:59 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/qemux86-64-homeassistant with version landingpage
20-12-23 19:40:59 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
20-12-23 19:40:59 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
20-12-23 19:41:00 INFO (SyncWorker_0) [supervisor.docker.homeassistant] Starting Home Assistant homeassistant/qemux86-64-homeassistant with version landingpage
20-12-23 19:41:00 INFO (MainThread) [supervisor.hassos] Detect HassOS 5.9 / BootSlot A
20-12-23 19:41:00 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
20-12-23 19:41:00 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
20-12-23 19:43:58 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)
  cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://github.com/home-assistant/addons /data/addons/core
  stderr: 'Cloning into '/data/addons/core'...
fatal: unable to access 'https://github.com/home-assistant/addons/': OpenSSL SSL_connect: Connection reset by peer in connection to github.com:443
20-12-23 19:43:58 ERROR (MainThread) [supervisor.store] Can't load data from repository core
20-12-23 19:43:58 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/hassio-addons/repository repository: Cmd('git') failed due to: exit code(128)
  cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://github.com/hassio-addons/repository /data/addons/git/a0d7b954
  stderr: 'Cloning into '/data/addons/git/a0d7b954'...
fatal: unable to access 'https://github.com/hassio-addons/repository/': OpenSSL SSL_connect: Connection reset by peer in connection to github.com:443
20-12-23 19:43:58 ERROR (MainThread) [supervisor.store] Can't load data from repository https://github.com/hassio-addons/repository
20-12-23 19:43:58 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
20-12-23 19:43:58 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
20-12-23 19:43:58 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
20-12-23 19:43:58 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
20-12-23 19:43:58 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
20-12-23 19:43:58 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
20-12-23 19:43:58 INFO (MainThread) [supervisor.resolution.check] System checks complete
20-12-23 19:43:58 ERROR (MainThread) [supervisor.homeassistant.api] Can't update Home Assistant access token!
20-12-23 19:43:58 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
20-12-23 19:43:58 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
20-12-23 19:43:58 INFO (MainThread) [__main__] Running Supervisor
20-12-23 19:44:02 INFO (MainThread) [supervisor.hassos] Rauc: A - marked slot kernel.0 as good
20-12-23 19:44:02 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
20-12-23 19:44:02 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
20-12-23 19:44:02 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
20-12-23 19:44:02 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
20-12-23 19:44:02 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
20-12-23 19:44:02 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
20-12-23 19:44:02 INFO (MainThread) [supervisor.misc.hwmon] Started Supervisor hardware monitor
20-12-23 19:44:02 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-12-23 19:44:02 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
20-12-23 19:44:02 INFO (MainThread) [supervisor.host.info] Updating local host information
20-12-23 19:44:02 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/qemux86-64-homeassistant:landingpage to homeassistant/qemux86-64-homeassistant:2020.12.1
20-12-23 19:44:02 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/qemux86-64-homeassistant with tag 2020.12.1.
20-12-23 19:44:02 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
20-12-23 19:44:02 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
20-12-23 19:44:02 INFO (MainThread) [supervisor.resolution.fixups.store_execute_remove] Remove invalid Store: core
20-12-23 19:44:02 ERROR (MainThread) [supervisor.store.repository] Can't remove built-in repositories!
20-12-23 19:44:02 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
20-12-23 19:44:03 INFO (MainThread) [supervisor.host.services] Updating service information
20-12-23 19:44:03 INFO (MainThread) [supervisor.host.network] Updating local network information
20-12-23 19:44:05 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
20-12-23 19:44:05 INFO (MainThread) [supervisor.host] Host information reload completed
20-12-23 19:44:17 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:2020.12.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.1&fromImage=homeassistant%2Fqemux86-64-homeassistant: Internal Server Error ("Get "https://registry-1.docker.io/v2/": net/http: TLS handshake timeout").
20-12-23 19:44:17 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
20-12-23 19:44:47 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/qemux86-64-homeassistant:landingpage to homeassistant/qemux86-64-homeassistant:2020.12.1
20-12-23 19:44:47 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/qemux86-64-homeassistant with tag 2020.12.1.
20-12-23 19:44:57 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:2020.12.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.1&fromImage=homeassistant%2Fqemux86-64-homeassistant: Internal Server Error ("Get "https://registry-1.docker.io/v2/": net/http: TLS handshake timeout").
20-12-23 19:44:57 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
20-12-23 19:45:27 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image homeassistant/qemux86-64-homeassistant:landingpage to homeassistant/qemux86-64-homeassistant:2020.12.1
20-12-23 19:45:27 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image homeassistant/qemux86-64-homeassistant with tag 2020.12.1.
20-12-23 19:45:37 ERROR (SyncWorker_2) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:2020.12.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.1&fromImage=homeassistant%2Fqemux86-64-homeassistant: Internal Server Error ("Get "https://registry-1.docker.io/v2/": net/http: TLS handshake timeout").
20-12-23 19:45:37 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
20-12-23 19:46:07 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image homeassistant/qemux86-64-homeassistant:landingpage to homeassistant/qemux86-64-homeassistant:2020.12.1
20-12-23 19:46:07 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/qemux86-64-homeassistant with tag 2020.12.1.
20-12-23 19:46:18 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:2020.12.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.1&fromImage=homeassistant%2Fqemux86-64-homeassistant: Internal Server Error ("Get "https://registry-1.docker.io/v2/": net/http: TLS handshake timeout").
20-12-23 19:46:18 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
20-12-23 19:46:48 INFO (SyncWorker_3) [supervisor.docker.interface] Updating image homeassistant/qemux86-64-homeassistant:landingpage to homeassistant/qemux86-64-homeassistant:2020.12.1
20-12-23 19:46:48 INFO (SyncWorker_3) [supervisor.docker.interface] Downloading docker image homeassistant/qemux86-64-homeassistant with tag 2020.12.1.
20-12-23 19:47:03 ERROR (SyncWorker_3) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:2020.12.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.1&fromImage=homeassistant%2Fqemux86-64-homeassistant: Internal Server Error ("Get "https://registry-1.docker.io/v2/": context deadline exceeded").
20-12-23 19:47:03 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
20-12-23 19:47:33 INFO (SyncWorker_3) [supervisor.docker.interface] Updating image homeassistant/qemux86-64-homeassistant:landingpage to homeassistant/qemux86-64-homeassistant:2020.12.1
20-12-23 19:47:33 INFO (SyncWorker_3) [supervisor.docker.interface] Downloading docker image homeassistant/qemux86-64-homeassistant with tag 2020.12.1.
20-12-23 19:47:43 ERROR (SyncWorker_3) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:2020.12.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.1&fromImage=homeassistant%2Fqemux86-64-homeassistant: Internal Server Error ("Get "https://registry-1.docker.io/v2/": net/http: TLS handshake timeout").
20-12-23 19:47:43 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
20-12-23 19:48:13 INFO (SyncWorker_3) [supervisor.docker.interface] Updating image homeassistant/qemux86-64-homeassistant:landingpage to homeassistant/qemux86-64-homeassistant:2020.12.1
20-12-23 19:48:13 INFO (SyncWorker_3) [supervisor.docker.interface] Downloading docker image homeassistant/qemux86-64-homeassistant with tag 2020.12.1.
20-12-23 19:48:24 ERROR (SyncWorker_3) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:2020.12.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.1&fromImage=homeassistant%2Fqemux86-64-homeassistant: Internal Server Error ("Get "https://registry-1.docker.io/v2/": net/http: TLS handshake timeout").
20-12-23 19:48:24 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
20-12-23 19:48:54 INFO (SyncWorker_4) [supervisor.docker.interface] Updating image homeassistant/qemux86-64-homeassistant:landingpage to homeassistant/qemux86-64-homeassistant:2020.12.1
20-12-23 19:48:54 INFO (SyncWorker_4) [supervisor.docker.interface] Downloading docker image homeassistant/qemux86-64-homeassistant with tag 2020.12.1.
20-12-23 19:49:09 ERROR (SyncWorker_4) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:2020.12.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.1&fromImage=homeassistant%2Fqemux86-64-homeassistant: Internal Server Error ("Get "https://registry-1.docker.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)").
20-12-23 19:49:09 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
20-12-23 19:49:39 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image homeassistant/qemux86-64-homeassistant:landingpage to homeassistant/qemux86-64-homeassistant:2020.12.1
20-12-23 19:49:39 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/qemux86-64-homeassistant with tag 2020.12.1.
20-12-23 19:49:54 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:2020.12.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.1&fromImage=homeassistant%2Fqemux86-64-homeassistant: Internal Server Error ("Get "https://registry-1.docker.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)").
20-12-23 19:49:54 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
20-12-23 19:50:24 INFO (SyncWorker_4) [supervisor.docker.interface] Updating image homeassistant/qemux86-64-homeassistant:landingpage to homeassistant/qemux86-64-homeassistant:2020.12.1
20-12-23 19:50:24 INFO (SyncWorker_4) [supervisor.docker.interface] Downloading docker image homeassistant/qemux86-64-homeassistant with tag 2020.12.1.
20-12-23 19:50:39 ERROR (SyncWorker_4) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:2020.12.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.1&fromImage=homeassistant%2Fqemux86-64-homeassistant: Internal Server Error ("Get "https://registry-1.docker.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)").
20-12-23 19:50:39 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
20-12-23 19:51:09 INFO (SyncWorker_4) [supervisor.docker.interface] Updating image homeassistant/qemux86-64-homeassistant:landingpage to homeassistant/qemux86-64-homeassistant:2020.12.1
20-12-23 19:51:09 INFO (SyncWorker_4) [supervisor.docker.interface] Downloading docker image homeassistant/qemux86-64-homeassistant with tag 2020.12.1.
20-12-23 19:51:24 ERROR (SyncWorker_4) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:2020.12.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.1&fromImage=homeassistant%2Fqemux86-64-homeassistant: Internal Server Error ("Get "https://registry-1.docker.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)").
20-12-23 19:51:24 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
20-12-23 19:51:54 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/qemux86-64-homeassistant:landingpage to homeassistant/qemux86-64-homeassistant:2020.12.1
20-12-23 19:51:54 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/qemux86-64-homeassistant with tag 2020.12.1.
20-12-23 19:52:09 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:2020.12.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.1&fromImage=homeassistant%2Fqemux86-64-homeassistant: Internal Server Error ("Get "https://registry-1.docker.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)").
20-12-23 19:52:09 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
20-12-23 19:52:39 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image homeassistant/qemux86-64-homeassistant:landingpage to homeassistant/qemux86-64-homeassistant:2020.12.1
20-12-23 19:52:39 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/qemux86-64-homeassistant with tag 2020.12.1.
20-12-23 19:52:49 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:2020.12.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.1&fromImage=homeassistant%2Fqemux86-64-homeassistant: Internal Server Error ("Get "https://registry-1.docker.io/v2/": net/http: TLS handshake timeout").
20-12-23 19:52:49 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
20-12-23 19:53:19 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/qemux86-64-homeassistant:landingpage to homeassistant/qemux86-64-homeassistant:2020.12.1
20-12-23 19:53:19 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/qemux86-64-homeassistant with tag 2020.12.1.
20-12-23 19:53:29 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:2020.12.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.1&fromImage=homeassistant%2Fqemux86-64-homeassistant: Internal Server Error ("Get "https://registry-1.docker.io/v2/": net/http: TLS handshake timeout").
20-12-23 19:53:29 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
20-12-23 19:54:00 INFO (SyncWorker_3) [supervisor.docker.interface] Updating image homeassistant/qemux86-64-homeassistant:landingpage to homeassistant/qemux86-64-homeassistant:2020.12.1
20-12-23 19:54:00 INFO (SyncWorker_3) [supervisor.docker.interface] Downloading docker image homeassistant/qemux86-64-homeassistant with tag 2020.12.1.
20-12-23 19:54:10 ERROR (SyncWorker_3) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:2020.12.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.1&fromImage=homeassistant%2Fqemux86-64-homeassistant: Internal Server Error ("Get "https://registry-1.docker.io/v2/": net/http: TLS handshake timeout").
20-12-23 19:54:10 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
20-12-23 19:54:40 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image homeassistant/qemux86-64-homeassistant:landingpage to homeassistant/qemux86-64-homeassistant:2020.12.1
20-12-23 19:54:40 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image homeassistant/qemux86-64-homeassistant with tag 2020.12.1.
20-12-23 19:54:55 ERROR (SyncWorker_2) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:2020.12.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.1&fromImage=homeassistant%2Fqemux86-64-homeassistant: Internal Server Error ("Get "https://registry-1.docker.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)").
20-12-23 19:54:55 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
The Error keeps the same for 4.20 and 5.8. I supect an error somewhere on the github server
logs from initial boot with a fresh hassos_ova-4.20.vdi http://192.168.11.194:8123/observer/logs
[fix-attrs.d] done.
[20:06:01] INFO: Update udev information
[cont-init.d] done.
[services.d] done.
[20:06:03] INFO: Starting local supervisor watchdog...
20-12-23 20:06:04 INFO (MainThread) [__main__] Initializing Supervisor setup
20-12-23 20:06:04 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
20-12-23 20:06:04 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
20-12-23 20:06:04 WARNING (MainThread) [supervisor.utils.dt] Can't fetch freegeoip data: Cannot connect to host ip-api.com:80 ssl:default [Connect call failed ('0.0.0.0', 80)]
20-12-23 20:06:04 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
20-12-23 20:06:04 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/amd64-hassio-supervisor with version 2020.12.6
20-12-23 20:06:04 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
20-12-23 20:06:04 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
20-12-23 20:06:04 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
20-12-23 20:06:04 INFO (MainThread) [__main__] Setting up Supervisor
20-12-23 20:06:04 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
20-12-23 20:06:04 INFO (MainThread) [supervisor.host.info] Updating local host information
20-12-23 20:06:04 INFO (MainThread) [supervisor.host.services] Updating service information
20-12-23 20:06:04 INFO (MainThread) [supervisor.host.network] Updating local network information
20-12-23 20:06:04 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
20-12-23 20:06:04 INFO (MainThread) [supervisor.host] Host information reload completed
20-12-23 20:06:04 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
20-12-23 20:06:04 INFO (MainThread) [supervisor.host.services] Reloading local service hassos-apparmor.service
20-12-23 20:06:04 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/amd64-hassio-dns versions: ['2020.11.0']
20-12-23 20:06:04 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/amd64-hassio-dns with version 2020.11.0
20-12-23 20:06:04 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
20-12-23 20:06:05 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS homeassistant/amd64-hassio-dns with version 2020.11.0 - 172.30.32.3
20-12-23 20:06:05 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
20-12-23 20:06:05 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/amd64-hassio-audio versions: ['17']
20-12-23 20:06:05 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/amd64-hassio-audio with version 17
20-12-23 20:06:05 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
20-12-23 20:06:05 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio homeassistant/amd64-hassio-audio with version 17 - 172.30.32.4
20-12-23 20:06:05 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/amd64-hassio-cli versions: ['2020.11.1']
20-12-23 20:06:05 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/amd64-hassio-cli with version 2020.11.1
20-12-23 20:06:05 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
20-12-23 20:06:05 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI homeassistant/amd64-hassio-cli with version 2020.11.1 - 172.30.32.5
20-12-23 20:06:05 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/amd64-hassio-observer versions: ['2020.10.1']
20-12-23 20:06:05 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/amd64-hassio-observer with version 2020.10.1
20-12-23 20:06:05 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
20-12-23 20:06:06 INFO (SyncWorker_0) [supervisor.docker.observer] Starting Observer homeassistant/amd64-hassio-observer with version 2020.10.1 - 172.30.32.6
20-12-23 20:06:06 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/amd64-hassio-multicast versions: ['3']
20-12-23 20:06:06 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/amd64-hassio-multicast with version 3
20-12-23 20:06:06 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
20-12-23 20:06:06 INFO (SyncWorker_0) [supervisor.docker.multicast] Starting Multicast homeassistant/amd64-hassio-multicast with version 3 - Host
20-12-23 20:06:06 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
20-12-23 20:06:10 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
20-12-23 20:06:10 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/qemux86-64-homeassistant versions: ['landingpage']
20-12-23 20:06:10 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/qemux86-64-homeassistant with version landingpage
20-12-23 20:06:10 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
20-12-23 20:06:10 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
20-12-23 20:06:10 INFO (SyncWorker_0) [supervisor.docker.homeassistant] Starting Home Assistant homeassistant/qemux86-64-homeassistant with version landingpage
20-12-23 20:06:10 INFO (MainThread) [supervisor.hassos] Detect HassOS 4.20 / BootSlot A
20-12-23 20:06:10 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
20-12-23 20:06:10 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
20-12-23 20:09:10 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/hassio-addons/repository repository: Cmd('git') failed due to: exit code(128)
20-12-23 20:09:10 ERROR (MainThread) [supervisor.store] Can't load data from repository https://github.com/hassio-addons/repository
20-12-23 20:09:10 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)
20-12-23 20:09:10 ERROR (MainThread) [supervisor.store] Can't load data from repository core
20-12-23 20:09:10 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
20-12-23 20:09:10 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
20-12-23 20:09:10 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
20-12-23 20:09:10 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
20-12-23 20:09:10 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
20-12-23 20:09:10 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
20-12-23 20:09:10 INFO (MainThread) [supervisor.resolution.check] System checks complete
20-12-23 20:09:10 ERROR (MainThread) [supervisor.homeassistant.api] Can't update Home Assistant access token!
20-12-23 20:09:10 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
20-12-23 20:09:11 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
20-12-23 20:09:11 INFO (MainThread) [__main__] Running Supervisor
20-12-23 20:09:14 INFO (MainThread) [supervisor.hassos] Rauc: A - marked slot kernel.0 as good
20-12-23 20:09:14 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2020.12.7
20-12-23 20:09:14 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/amd64-hassio-supervisor with tag 2020.12.7.
20-12-23 20:09:24 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install homeassistant/amd64-hassio-supervisor:2020.12.7 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.7&fromImage=homeassistant%2Famd64-hassio-supervisor: Internal Server Error ("Get https://registry-1.docker.io/v2/: net/http: TLS handshake timeout").
20-12-23 20:09:24 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor failed!
20-12-23 20:09:24 CRITICAL (MainThread) [supervisor.core] Can't update Supervisor! This will break some Add-ons or affect future version of Home Assistant!
20-12-23 20:09:24 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
20-12-23 20:09:24 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
20-12-23 20:09:24 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
20-12-23 20:09:24 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
20-12-23 20:09:24 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
20-12-23 20:09:24 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
20-12-23 20:09:24 INFO (MainThread) [supervisor.misc.hwmon] Started Supervisor hardware monitor
20-12-23 20:09:24 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-12-23 20:09:24 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
20-12-23 20:09:24 INFO (MainThread) [supervisor.host.info] Updating local host information
20-12-23 20:09:24 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/qemux86-64-homeassistant:landingpage to homeassistant/qemux86-64-homeassistant:2020.12.1
20-12-23 20:09:24 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/qemux86-64-homeassistant with tag 2020.12.1.
20-12-23 20:09:24 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
20-12-23 20:09:24 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
20-12-23 20:09:24 INFO (MainThread) [supervisor.resolution.fixups.store_execute_remove] Remove invalid Store: a0d7b954
20-12-23 20:09:24 INFO (MainThread) [supervisor.store.git] Removing custom add-on repository https://github.com/hassio-addons/repository
20-12-23 20:09:24 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
20-12-23 20:09:25 INFO (MainThread) [supervisor.host.services] Updating service information
20-12-23 20:09:25 INFO (MainThread) [supervisor.host.network] Updating local network information
20-12-23 20:09:26 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
20-12-23 20:09:26 INFO (MainThread) [supervisor.host] Host information reload completed
20-12-23 20:09:35 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:2020.12.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.1&fromImage=homeassistant%2Fqemux86-64-homeassistant: Internal Server Error ("Get https://registry-1.docker.io/v2/: net/http: TLS handshake timeout").
20-12-23 20:09:35 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
[https://github.com/home-assistant/operating-system/releases/tag/4.2]
This one is better
https://github.com/home-assistant/operating-system/tags
Same, but without a oberserver/log page
This worked for me as well, thank you for the guidance!
No problem. Enjoy your holidays with new update.
Same, fixed my problem! Thanks.
Also, glad I learned a few new ha commands especially how to revert, those will come in handy. They should be a bit more prominently mentioned in documentation/error text.
Any ideas on a timeline for a true fix?
Anything new?
Also hoping for an update, I am attempting a fresh install.
I am setting the dns when I set static ip and it’s not helping.
EDIT!
So after leaving it for a few hours Home Assistant final got grabbed from docker, no idea how but it did. The issue now is that I can’t use it to grab any add ons cause I am still getting the 500 even after adding google dns and 9.9.9.9 dns as well.
Same here. Updating IPv4 DNS to static did not help. Connection problems when installing add-ons and updating to 2020.12.2. All of them are resolved by rolling back OS to 4.2.
Does anyone know if this issue has been raised with the developers?
Alright so I am going to take a shot in the dark at what is happening here cause it’s half working.
Yesterday I tried to install samba and it failed today it was sucessful, my guess is that when you hit install the first time it does the docker pull but then goes to check the local registry and because it’s not there it fails, which is why it works the day after for me.
EDIT: So I’m pretty sure I have confirmed I am right cause this morning it appears to be working correctly cause now when installing node-red it waits for the image to be grabbed.
EDIT2: Weird it appears to still be happening to some add ons. Just went to install adguard home and I get the error, but as mentioned before I’ll wait a bit and see if it’s successful when I try again.
EDIT3: This is not an issue with docker login, I setup ssh and it’s still not working. I am not sure why I was able to download the previous addons but for some reason this one is not working.
I installed last 5.9 version on a RPI 4 days ago and it has sat running failing to upgrade …
I have also rebooted everyday during this 4 days.
Guy on Discord channel says to try connecting RPi directly to my router - this makes not difference.
Same guy said to try adding it to DMZ - stiil fails.
Next he says to buy new router …
Just installed latest 5.10 image to my RPi and still broken …
