i just installed hass.io installed a few addons from repo (mosquitto,samba,ssh) - works fine. The problem is that when I want to run my own addond locally a get following error:
17-10-06 20:18:14 INFO (SyncWorker_19) [hassio.dock.addon] Start build local/armhf-addon-test:0.1
17-10-06 20:18:17 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 422, in start
resp = yield from self._request_handler(request)
File "/usr/lib/python3.6/site-packages/aiohttp/web.py", line 306, in _handle
resp = yield from handler(request)
File "/usr/lib/python3.6/site-packages/hassio/api/util.py", line 31, in wrap_api
answer = await method(api, *args, **kwargs)
File "/usr/lib/python3.6/site-packages/hassio/api/addons.py", line 176, in install
addon.install(version=version), loop=self.loop)
File "/usr/lib/python3.6/site-packages/hassio/addons/addon.py", line 467, in install
if not await self.docker.install(version):
File "/usr/lib/python3.6/site-packages/hassio/dock/util.py", line 18, in wrap_api
return await method(api, *args, **kwargs)
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run
File "/usr/lib/python3.6/site-packages/hassio/dock/addon.py", line 198, in _install
return self._build(tag)
File "/usr/lib/python3.6/site-packages/hassio/dock/addon.py", line 211, in _build
image = self.docker.images.build(**build_env.get_docker_args(tag))
File "/usr/lib/python3.6/site-packages/docker/models/images.py", line 175, in build
raise BuildError(chunk['error'])
docker.errors.BuildError: oci runtime error: container_linux.go:263: starting container process caused "exec: \"/bin/sh\": stat /bin/sh: no such file or directory"
Here are my source files
run.sh
#!/bin/bash
set -e
echo "Hello world!"
Dockerfile
ARG BUILD_ARG
FROM $BUILD_FROM
# Add env
ENV LANG C.UTF-8
# Setup base
RUN apk add --no-cache jq
# Copy data
COPY run.sh /
RUN chmod a+x /run.sh
CMD [ "/run.sh" ]
config.json
"name": "my test",
"version": "0.1",
"slug": "test",
"description": "test",
"startup": "before",
"boot": "auto",
"arch": ["armhf"],
"options": {},
"schema": {}
Supervisor: 0.68
Host OS: Control version: 1.1
HA: 0.54
What is the problem?
