Hi
I install node -red from hassio and it started all great but when I add a “node-red-contrib-mysensors” package to the config and restart it crashed. I attached the log…
what am I missing?
log:
[email protected] install /opt/node_modules/sqlite3
> node-pre-gyp install --fallback-to-build
node-pre-gyp WARN Using request for node-pre-gyp https download
node-pre-gyp WARN Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/…/node-v57-linu…
node-pre-gyp WARN Pre-built binaries not found for [email protected] and [email protected] (node-v57 ABI, musl) (falling back to source compile with node-gyp)
gyp ERR! build error
gyp ERR! stack Error: not found: make
gyp ERR! stack at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:13:12)
gyp ERR! stack at F (/usr/lib/node_modules/npm/node_modules/which/which.js:68:19)
gyp ERR! stack at E (/usr/lib/node_modules/npm/node_modules/which/which.js:80:29)
gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:89:16
gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/isexe/index.js:42:5
gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
gyp ERR! stack at FSReqWrap.oncomplete (fs.js:152:21)
gyp ERR! System Linux 4.14.81-v7
gyp ERR! command “/usr/bin/node” “/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “build” “–fallback-to-build” “–module=/opt/node_modules/sqlite3/lib/binding/node-v57-linux-arm/node_sqlite3.node” “–module_name=node_sqlite3” “–module_path=/opt/node_modules/sqlite3/lib/binding/node-v57-linux-arm” “–napi_version=3” “–node_abi_napi=napi” “–napi_build_version=0” “–node_napi_label=node-v57”
gyp ERR! cwd /opt/node_modules/sqlite3
gyp ERR! node -v v8.14.0
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute ‘/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/node_modules/sqlite3/lib/binding/node-v57-linux-arm/node_sqlite3.node --module_name=node_sqlite3 --module_path=/opt/node_modules/sqlite3/lib/binding/node-v57-linux-arm --napi_version=3 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57’ (1)
node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! stack at emitTwo (events.js:126:13)
node-pre-gyp ERR! stack at ChildProcess.emit (events.js:214:7)
node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:915:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
node-pre-gyp ERR! System Linux 4.14.81-v7
node-pre-gyp ERR! command “/usr/bin/node” “/opt/node_modules/.bin/node-pre-gyp” “install” “–fallback-to-build”
node-pre-gyp ERR! cwd /opt/node_modules/sqlite3
node-pre-gyp ERR! node -v v8.14.0
node-pre-gyp ERR! node-pre-gyp -v v0.11.0
node-pre-gyp ERR! not ok
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] install: node-pre-gyp install --fallback-to-build
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2019-02-17T18_14_18_579Z-debug.log
FATAL: Failed installing npm package node-red-contrib-mysensors
[cont-init.d] 81-npm-packages.sh: exited 1.
[cont-finish.d] executing container finish scripts…
[cont-finish.d] 99-message.sh: executing…
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] syncing disks.
[s6-finish] sending all processes the TERM signal.
