Can't install node-red-contrib-rfxcom
I try to install node-red-contrib-rfxcom in Node-Red but receive an error.
2022-11-18T08:03:48.040Z Install : node-red-contrib-rfxcom 2.11.3
2022-11-18T08:03:47.991Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict [email protected]
2022-11-18T08:03:48.633Z [err] npm
2022-11-18T08:03:48.633Z [err]  WARN
2022-11-18T08:03:48.633Z [err]  config production Use `--omit=dev` instead.
2022-11-18T08:03:54.609Z [err] npm
2022-11-18T08:03:54.609Z [err]  WARN deprecated [email protected]: 3.x is no longer supported. Please upgrade to 4.x or higher.
2022-11-18T08:03:55.650Z [err] npm
2022-11-18T08:03:55.650Z [err]  ERR! code 1
2022-11-18T08:03:55.650Z [err] npm ERR!
2022-11-18T08:03:55.650Z [err] path /config/node-red/node_modules/@serialport/bindings
2022-11-18T08:03:55.653Z [err] npm
2022-11-18T08:03:55.653Z [err] ERR! command failed
2022-11-18T08:03:55.654Z [err] command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
2022-11-18T08:03:55.654Z [err] npm ERR!
2022-11-18T08:03:55.654Z [err]  prebuild-install warn install No prebuilt binaries found (target=16.17.1 runtime=node arch=x64 libc=musl platform=linux)
2022-11-18T08:03:55.654Z [err] npm ERR! gyp info it worked if it ends with ok
2022-11-18T08:03:55.654Z [err]  gyp info using [email protected]
2022-11-18T08:03:55.654Z [err] ERR! gyp info using [email protected] | linux | x64
2022-11-18T08:03:55.654Z [err] npm ERR! gyp ERR! find Python
2022-11-18T08:03:55.654Z [err] npm ERR! gyp ERR! find Python checking Python explicitly set from command line or npm configuration
2022-11-18T08:03:55.654Z [err] npm ERR! gyp ERR! find Python - "--python=" or "npm config get python" is "/usr/bin/python3"
2022-11-18T08:03:55.655Z [err] ERR! gyp ERR! find Python - "/usr/bin/python3" is not in PATH or produced an error
2022-11-18T08:03:55.655Z [err] npm ERR! gyp ERR! find Python Python is not set from environment variable PYTHON
2022-11-18T08:03:55.655Z [err]  gyp ERR! find Python checking if "python3" can be used
2022-11-18T08:03:55.655Z [err] npm ERR! gyp ERR! find Python - "python3" is not in PATH or produced an error
2022-11-18T08:03:55.655Z [err]  gyp ERR! find Python checking if "python" can be used
2022-11-18T08:03:55.655Z [err] npm ERR! gyp ERR! find Python - "python" is not in PATH or produced an error
2022-11-18T08:03:55.655Z [err] npm ERR! gyp ERR! find Python **********************************************************
2022-11-18T08:03:55.655Z [err] npm ERR! gyp ERR! find Python You need to install the latest version of Python.
2022-11-18T08:03:55.655Z [err] npm ERR! gyp ERR! find Python Node-gyp should be able to find and use Python. If not,
2022-11-18T08:03:55.655Z [err] npm ERR! gyp ERR! find Python you can try one of the following options:
2022-11-18T08:03:55.655Z [err] npm ERR! gyp ERR! find Python - Use the switch --python="/path/to/pythonexecutable"
2022-11-18T08:03:55.655Z [err] npm ERR! gyp ERR! find Python   (accepted by both node-gyp and npm)
2022-11-18T08:03:55.655Z [err]  ERR! gyp ERR! find Python - Set the environment variable PYTHON
2022-11-18T08:03:55.655Z [err] npm ERR! gyp ERR! find Python - Set the npm configuration variable python:
2022-11-18T08:03:55.655Z [err]  ERR! gyp ERR! find Python   npm config set python "/path/to/pythonexecutable"
2022-11-18T08:03:55.655Z [err] npm ERR! gyp ERR! find Python For more information consult the documentation at:
2022-11-18T08:03:55.656Z [err]  ERR! gyp ERR! find Python https://github.com/nodejs/node-gyp#installation
2022-11-18T08:03:55.656Z [err] npm ERR! gyp ERR! find Python **********************************************************
2022-11-18T08:03:55.656Z [err] npm ERR! gyp ERR! configure error
2022-11-18T08:03:55.656Z [err]  ERR! gyp ERR! stack Error: Could not find any Python installation to use
2022-11-18T08:03:55.656Z [err] npm ERR! gyp ERR! stack     at PythonFinder.fail (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:330:47)
2022-11-18T08:03:55.656Z [err] npm ERR! gyp ERR! stack     at PythonFinder.runChecks (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:159:21)
2022-11-18T08:03:55.656Z [err] npm ERR! gyp ERR! stack     at PythonFinder.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:202:16)
2022-11-18T08:03:55.656Z [err]  ERR! gyp ERR! stack     at PythonFinder.execFileCallback (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:294:16)
2022-11-18T08:03:55.656Z [err] npm ERR! gyp ERR! stack     at exithandler (node:child_process:408:5)
2022-11-18T08:03:55.656Z [err] npm ERR! gyp ERR! stack     at ChildProcess.errorhandler (node:child_process:420:5)
2022-11-18T08:03:55.656Z [err] npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:513:28)
2022-11-18T08:03:55.656Z [err]  ERR! gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:289:12)
2022-11-18T08:03:55.656Z [err] npm ERR! gyp ERR! stack     at onErrorNT (node:internal/child_process:478:16)
2022-11-18T08:03:55.656Z [err] ERR! gyp ERR! stack     at processTicksAndRejections (node:internal/process/task_queues:83:21)
2022-11-18T08:03:55.656Z [err] npm ERR! gyp ERR! System Linux 5.15.74
2022-11-18T08:03:55.656Z [err]  ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
2022-11-18T08:03:55.656Z [err] npm ERR! gyp ERR! cwd /config/node-red/node_modules/@serialport/bindings
2022-11-18T08:03:55.657Z [err] ERR! gyp ERR! node -v v16.17.1
2022-11-18T08:03:55.657Z [err] npm ERR! gyp ERR! node-gyp -v v9.0.0
2022-11-18T08:03:55.657Z [err] ERR! gyp ERR! not ok
2022-11-18T08:03:55.660Z [err]
2022-11-18T08:03:55.660Z [err] npm ERR!
2022-11-18T08:03:55.660Z [err]  A complete log of this run can be found in:
2022-11-18T08:03:55.660Z [err] npm ERR!     /root/.npm/_logs/2022-11-18T08_03_48_573Z-debug-0.log
2022-11-18T08:03:55.670Z rc=1
Dose anyone know how to solve this?
Very late reply, but I had the same issue and ended up here.
The instructions in this post fixed it for me: Node-red-contrib-rfxcom stopped working - Third party integrations / Node-RED - Home Assistant Community (home-assistant.io).
