hey all, im trying to install arduino module via the manage pallet after upgrading to the newest node-red, i am running supervisor install
my system is
Version core-2021.11.2
Version supervisor-2021.10.8
Operating System Debian GNU/Linux 10 (buster)
Docker version 20.10.9
Channel beta
this is my error message
2021-11-11T20:26:42.838Z Install : node-red-node-arduino 0.3.1
2021-11-11T20:26:42.887Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict [email protected]
2021-11-11T20:27:07.082Z [err] npm
2021-11-11T20:27:07.082Z [err] ERR! code 1
2021-11-11T20:27:07.082Z [err] npm ERR! path /config/node-red/node_modules/@serialport/bindings
2021-11-11T20:27:07.085Z [err] npm ERR!
2021-11-11T20:27:07.085Z [err] command failed
2021-11-11T20:27:07.085Z [err] npm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
2021-11-11T20:27:07.085Z [err] npm ERR! gyp info it worked if it ends with ok
2021-11-11T20:27:07.085Z [err] npm ERR! gyp info using [email protected]
2021-11-11T20:27:07.085Z [err] npm ERR! gyp info using [email protected] | linux | x64
2021-11-11T20:27:07.085Z [err] npm ERR! gyp info find Python using Python version 3.9.5 found at "/usr/bin/python3"
2021-11-11T20:27:07.085Z [err] ERR! gyp info spawn /usr/bin/python3
2021-11-11T20:27:07.085Z [err] npm ERR! gyp info spawn args [
2021-11-11T20:27:07.085Z [err] gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
2021-11-11T20:27:07.085Z [err] npm ERR! gyp info spawn args 'binding.gyp',
2021-11-11T20:27:07.085Z [err] npm ERR! gyp info spawn args '-f',
2021-11-11T20:27:07.085Z [err] ERR! gyp info spawn args 'make',
2021-11-11T20:27:07.085Z [err] npm ERR! gyp info spawn args '-I',
2021-11-11T20:27:07.085Z [err] npm ERR! gyp info spawn args '/config/node-red/node_modules/@serialport/bindings/build/config.gypi',
2021-11-11T20:27:07.086Z [err] npm ERR! gyp info spawn args '-I',
2021-11-11T20:27:07.086Z [err] npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
2021-11-11T20:27:07.086Z [err] npm ERR! gyp info spawn args '/root/.cache/node-gyp/14.18.1/include/node/common.gypi',
2021-11-11T20:27:07.086Z [err] npm ERR! gyp info spawn args '-Dlibrary=shared_library',
2021-11-11T20:27:07.086Z [err] gyp info spawn args '-Dvisibility=default',
2021-11-11T20:27:07.086Z [err] npm ERR! gyp info spawn args '-Dnode_root_dir=/root/.cache/node-gyp/14.18.1',
2021-11-11T20:27:07.086Z [err] npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
2021-11-11T20:27:07.086Z [err] npm ERR! gyp info spawn args '-Dnode_lib_file=/root/.cache/node-gyp/14.18.1/<(target_arch)/node.lib',
2021-11-11T20:27:07.086Z [err] npm ERR! gyp info spawn args '-Dmodule_root_dir=/config/node-red/node_modules/@serialport/bindings',
2021-11-11T20:27:07.086Z [err] ERR! gyp info spawn args '-Dnode_engine=v8',
2021-11-11T20:27:07.086Z [err] npm ERR! gyp info spawn args '--depth=.',
2021-11-11T20:27:07.086Z [err] gyp info spawn args '--no-parallel',
2021-11-11T20:27:07.086Z [err] npm ERR! gyp info spawn args '--generator-output',
2021-11-11T20:27:07.086Z [err] npm ERR! gyp info spawn args 'build',
2021-11-11T20:27:07.086Z [err] ERR! gyp info spawn args '-Goutput_dir=.'
2021-11-11T20:27:07.086Z [err] npm ERR! gyp info spawn args ]
2021-11-11T20:27:07.086Z [err] gyp ERR! build error
2021-11-11T20:27:07.086Z [err] npm ERR! gyp ERR! stack Error: not found: make
2021-11-11T20:27:07.086Z [err] gyp ERR! stack at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:10:17)
2021-11-11T20:27:07.086Z [err] npm ERR! gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:57:18
2021-11-11T20:27:07.086Z [err] gyp ERR! stack at new Promise (<anonymous>)
2021-11-11T20:27:07.086Z [err] npm ERR! gyp ERR! stack at step (/usr/lib/node_modules/npm/node_modules/which/which.js:54:21)
2021-11-11T20:27:07.086Z [err] ERR! gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:71:22
2021-11-11T20:27:07.086Z [err] npm ERR! gyp ERR! stack at new Promise (<anonymous>)
2021-11-11T20:27:07.086Z [err] ERR! gyp ERR! stack at subStep (/usr/lib/node_modules/npm/node_modules/which/which.js:69:33)
2021-11-11T20:27:07.086Z [err] npm ERR! gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:80:22
2021-11-11T20:27:07.086Z [err] ERR! gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/isexe/index.js:42:5
2021-11-11T20:27:07.086Z [err] npm ERR! gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
2021-11-11T20:27:07.087Z [err] ERR! gyp ERR! System Linux 5.10.0-0.bpo.8-amd64
2021-11-11T20:27:07.087Z [err] npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
2021-11-11T20:27:07.087Z [err] ERR! gyp ERR! cwd /config/node-red/node_modules/@serialport/bindings
2021-11-11T20:27:07.087Z [err] npm ERR! gyp ERR! node -v v14.18.1
2021-11-11T20:27:07.087Z [err] ERR! gyp ERR! node-gyp -v v7.1.2
2021-11-11T20:27:07.087Z [err] npm ERR! gyp ERR! not ok
2021-11-11T20:27:07.112Z [err]
2021-11-11T20:27:07.112Z [err] npm ERR!
2021-11-11T20:27:07.112Z [err] A complete log of this run can be found in:
2021-11-11T20:27:07.112Z [err] npm ERR! /root/.npm/_logs/2021-11-11T20_27_07_089Z-debug.log
2021-11-11T20:27:07.133Z rc=1
