Can't Install the new Reolink integration
Having trouble setting up the new Reolink integration. I get this error:
See the troubleshooting steps if you encounter problems. Error registering URL for webhook reolink_ec71db62314a_ONVIF: HomeAssistant URL is not available
I have updated the firmware on the NVR and cameras, created an Admin acct for HA and enabled the server ports in the Reolink app.
Not sure what else to try. Any help is appreciated.
Larry in Denver
This is de camera reporting back to HA.
  1. Is HA reachable for the camera?
  2. Is the hostname properly registered in HA and resolvable for the camera?
  3. Does HA run without HTTPS? (The Reolink cameras are unable to handle this). I used “built-in” HTTPS as well, but after disabling it and using the proxy add-on it was solved.
