Hey there,
unfortunately my SD card broke and so I had to reinstall Raspberry Pi OS. I have now installed Raspberry Pi OS 11, unfortunately I can’t install the ZHA integration
In the Logs i see this error message
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-pd23l51f/rpi-gpio/source/common.h:36: multiple definition of `pin_to_gpio_rev3'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-pd23l51f/rpi-gpio/source/common.h:36: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-pd23l51f/rpi-gpio/source/common.h:35: multiple definition of `pin_to_gpio_rev2'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-pd23l51f/rpi-gpio/source/common.h:35: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-pd23l51f/rpi-gpio/source/common.h:34: multiple definition of `pin_to_gpio_rev1'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-pd23l51f/rpi-gpio/source/common.h:34: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-pd23l51f/rpi-gpio/source/common.h:33: multiple definition of `gpio_mode'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-pd23l51f/rpi-gpio/source/common.h:33: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/soft_pwm.o:/tmp/pip-install-pd23l51f/rpi-gpio/source/soft_pwm.c:28: multiple definition of `threads'; build/temp.linux-armv7l-3.9/source/event_gpio.o:/tmp/pip-install-pd23l51f/rpi-gpio/source/event_gpio.c:60: first defined here
collect2: error: ld returned 1 exit status
error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1
idk how to fix it. I don’t want to get back to Raspverry Pi OS 10 because of this error
