Can't listen to deconz_event
I would like to integrate the Hue wall module into my home assistant via Conbee 2. Pairing works wonderfully. I also already have various Hue lamps and Aqara stuff that works.
However, I can’t listen to devonz_event under localhost/developer-tools/event. No matter what device I trigger, nothing comes up. Do you guys have any ideas? Unfortunately, this seems to be essential for the rest of the setup. In the logs, only this message comes up:
Logger: zigpy.zcl
Source: /usr/local/lib/python3.9/site-packages/zigpy/zcl/__init__.py:114
First occurred: 20:37:34 (32 occurrences)
Last logged: 20:44:44
[0xecef:1:0xfc00] Unknown cluster-specific command 0
Thanks!
Are you sure that you are using the deconz integration and not ZHA?
I am such an idiot, you are right. Unfortunately the hue module is not recognized in ZHA.
