I’m a complete Newbie, Not sure what i’ve done wroing. I went into Hassio section and it said update to latest version. I did this now cant load home page. I can get into the RPI3 via SSH (Putty) but nothing else. Any help appreciated.
Try to clear cache and reload page.
That use to be the solution for me when similar issue occurs.
Thanks but unfortunately that didn’t work. Can I do anything from SSH? I’m not familiar with its commands.
try
cd /config
nano home-assistant.log
core-ssh:~# cd /config
core-ssh:/config# nano home-assistant.log
Then you will get the logfile hopefully telling you whats wrong…
If you want to try your luck rebooting the system from putty:
hassio host reboot
Thanks for that advice. Below is what it says. Should there be a logfile? I can get in fine via putty and have rebooted numerous times.
2018-11-12 21:16:23 ERROR (MainThread) [homeassistant.config] Invalid config for
[homeassistant]: $2018-11-12 21:16:23 ERROR (MainThread) [homeassistant.config] Invalid
config for
[homeassistant]: [group] is an invalid option for [homeassistant]. Check: homeassistant->group. (S$
OK Found the logfile.
2018-11-12 21:16:23 ERROR (MainThread) [homeassistant.config] Invalid config for [homeassistant]: [group] is an invalid option for [homeassistant]. Check: homeassistant->group. (See /config/configuration.yaml, line 1).
My configuration looks like this:
homeassistant:
Location required to calculate the time the sun rises and sets
latitude:
longitude:
Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 105
metric for Metric, imperial for Imperial
unit_system: metric
Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: GMT
customize: !include customize.yaml
group: !include groups.yaml
sensor: !include sensors.yaml
Been using like this for a few days but it reports to an error in line 1…
Make sure you have correct indentation.
Below are my first lines of code, available if you in putty type:
core-ssh:/config# nano configuration.yaml
My code:
homeassistant:
latitude: !secret lat_home
longitude: !secret long_home
elevation: 3
unit_system: metric
time_zone: !secret time_zone
customize: !include_dir_merge_named customize # !include customize.yaml
zone: !include includes/zone.yaml
frontend:
javascript_version: auto
config:
http:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# base_url: !secret my_baseurl
# server_port: 8123
# ssl_certificate: !secret ssl_certificate
# ssl_key: !secret ssl_key
# trusted_networks: !secret trusted_networks
# api_password: !secret http_password
updater:
Strange that it all worked until I did the upgrade… Is there a link to a fresh configuration.yaml?
Try this post:
Thanks for all your help, I replaced Configuration.yaml but still no joy. I think its a network problem. Need to sleep on it…
I got it. Luckily found another page, no idea how. Deleted the Google Cast instance in.storage/core.config and all working again.
