I have no idea what I did. Last thing I did was deleting the emulated_hue:
integration from the configuraton.yaml
. I already tried to revert that and checked the configuration for errors via the command line. I also wanted to restore partial updates but the supervisor is complaining that it is only partial. I would actually like to fix this. How can I debug?
The error is “Unable to connect to Home Assistant”
Core logs:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
2022-05-11 19:24:45 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration govee which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-05-11 19:24:45 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-05-11 19:24:45 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration openweathermap_all which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-05-11 19:24:47 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2022-05-11 19:24:47 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=136 from 2022-05-11 17:14:54.337315)
2022-05-11 19:24:59 WARNING (MainThread) [homeassistant.setup] Setup of hassio is taking over 10 seconds.
2022-05-11 19:25:15 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Localhost:19444' for hyperion integration not ready yet: None; Retrying in background
2022-05-11 19:25:16 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Hue Bridge e45f0126b335' for hue integration not ready yet: Error connecting to the Hue bridge at 192.168.184.71; Retrying in background
2022-05-11 19:25:22 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Samsung SCX-3400 Series' for syncthru integration not ready yet: Configured printer at http://192.168.184.20 does not respond.; Retrying in background
2022-05-11 19:25:22 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Samsung SCX-3400 Series (SEC001599E18DCF)' for ipp integration not ready yet: Invalid response from API: Error occurred while communicating with IPP server.; Retrying in background
2022-05-11 19:25:28 WARNING (MainThread) [homeassistant.components.mqtt.climate] The 'away_mode_command_topic' option is deprecated, please remove it from your configuration
2022-05-11 19:25:28 WARNING (MainThread) [homeassistant.components.mqtt.climate] The 'away_mode_state_template' option is deprecated, please remove it from your configuration
2022-05-11 19:25:28 WARNING (MainThread) [homeassistant.components.mqtt.climate] The 'away_mode_state_topic' option is deprecated, please remove it from your configuration
Supervisor logs
2-05-11 19:26:04 INFO (SyncWorker_7) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-aarch64 with version 1.25.1-1
22-05-11 19:26:05 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning addon_c863ef44_diyhue-master-branch application
22-05-11 19:26:05 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:26:05 WARNING (MainThread) [supervisor.addons.options] Option 'external_converters' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:26:05 WARNING (MainThread) [supervisor.addons.options] Option 'devices' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:26:05 WARNING (MainThread) [supervisor.addons.options] Option 'groups' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:26:05 WARNING (MainThread) [supervisor.addons.options] Option 'homeassistant' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:26:05 WARNING (MainThread) [supervisor.addons.options] Option 'permit_join' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:26:05 WARNING (MainThread) [supervisor.addons.options] Option 'advanced' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:26:05 WARNING (MainThread) [supervisor.addons.options] Option 'device_options' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:26:05 WARNING (MainThread) [supervisor.addons.options] Option 'blocklist' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:26:05 WARNING (MainThread) [supervisor.addons.options] Option 'passlist' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:26:05 WARNING (MainThread) [supervisor.addons.options] Option 'queue' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:26:05 WARNING (MainThread) [supervisor.addons.options] Option 'frontend' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:26:05 WARNING (MainThread) [supervisor.addons.options] Option 'experimental' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:26:05 WARNING (MainThread) [supervisor.addons.options] Option 'availability' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:26:22 INFO (SyncWorker_0) [supervisor.docker.addon] Starting Docker add-on c863ef44/aarch64-addon-diyhue-master-branch with version 2.0.0
22-05-11 19:26:23 INFO (SyncWorker_3) [supervisor.docker.interface] Cleaning addon_core_almond application
22-05-11 19:26:36 INFO (SyncWorker_3) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-almond with version 3.0.0
22-05-11 19:26:37 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning addon_dba1ceb5_hyperionng application
22-05-11 19:26:37 INFO (MainThread) [supervisor.api.middleware.security] /host/info access from c863ef44_diyhue-master-branch
22-05-11 19:26:55 INFO (SyncWorker_1) [supervisor.docker.addon] Starting Docker add-on bradsjm/hyperion-ng-addon-aarch64 with version 2.0.12
22-05-11 19:27:01 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
22-05-11 19:27:01 INFO (MainThread) [supervisor.core] Supervisor is up and running
22-05-11 19:27:01 INFO (MainThread) [supervisor.host.info] Updating local host information
22-05-11 19:27:01 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-05-11 19:27:01 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-05-11 19:27:01 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
22-05-11 19:27:01 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-05-11 19:27:01 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-05-11 19:27:01 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-05-11 19:27:01 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:27:01 WARNING (MainThread) [supervisor.addons.options] Option 'external_converters' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:27:01 WARNING (MainThread) [supervisor.addons.options] Option 'devices' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:27:01 WARNING (MainThread) [supervisor.addons.options] Option 'groups' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:27:01 WARNING (MainThread) [supervisor.addons.options] Option 'homeassistant' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:27:01 WARNING (MainThread) [supervisor.addons.options] Option 'permit_join' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:27:01 WARNING (MainThread) [supervisor.addons.options] Option 'advanced' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:27:01 WARNING (MainThread) [supervisor.addons.options] Option 'device_options' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:27:01 WARNING (MainThread) [supervisor.addons.options] Option 'blocklist' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:27:01 WARNING (MainThread) [supervisor.addons.options] Option 'passlist' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:27:01 WARNING (MainThread) [supervisor.addons.options] Option 'queue' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:27:01 WARNING (MainThread) [supervisor.addons.options] Option 'frontend' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:27:01 WARNING (MainThread) [supervisor.addons.options] Option 'experimental' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:27:01 WARNING (MainThread) [supervisor.addons.options] Option 'availability' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:27:01 WARNING (MainThread) [supervisor.addons.options] Unknown option 'password_authentication' for SSH & Web Terminal (a0d7b954_ssh)
22-05-11 19:27:15 WARNING (MainThread) [supervisor.utils.pwned] Can't fetch HIBP data: Timeout
22-05-11 19:27:15 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2mqtt Edge (45df7312_zigbee2mqtt_edge)
22-05-11 19:27:15 WARNING (MainThread) [supervisor.addons.options] Option 'external_converters' does not exist in the schema for Zigbee2mqtt Edge (45df7312_zigbee2mqtt_edge)
22-05-11 19:27:15 WARNING (MainThread) [supervisor.addons.options] Option 'devices' does not exist in the schema for Zigbee2mqtt Edge (45df7312_zigbee2mqtt_edge)
22-05-11 19:27:15 WARNING (MainThread) [supervisor.addons.options] Option 'groups' does not exist in the schema for Zigbee2mqtt Edge (45df7312_zigbee2mqtt_edge)
22-05-11 19:27:15 WARNING (MainThread) [supervisor.addons.options] Option 'homeassistant' does not exist in the schema for Zigbee2mqtt Edge (45df7312_zigbee2mqtt_edge)
22-05-11 19:27:15 WARNING (MainThread) [supervisor.addons.options] Option 'permit_join' does not exist in the schema for Zigbee2mqtt Edge (45df7312_zigbee2mqtt_edge)
22-05-11 19:27:15 WARNING (MainThread) [supervisor.addons.options] Option 'advanced' does not exist in the schema for Zigbee2mqtt Edge (45df7312_zigbee2mqtt_edge)
22-05-11 19:27:15 WARNING (MainThread) [supervisor.addons.options] Option 'device_options' does not exist in the schema for Zigbee2mqtt Edge (45df7312_zigbee2mqtt_edge)
22-05-11 19:27:15 WARNING (MainThread) [supervisor.addons.options] Option 'blocklist' does not exist in the schema for Zigbee2mqtt Edge (45df7312_zigbee2mqtt_edge)
22-05-11 19:27:15 WARNING (MainThread) [supervisor.addons.options] Option 'passlist' does not exist in the schema for Zigbee2mqtt Edge (45df7312_zigbee2mqtt_edge)
22-05-11 19:27:15 WARNING (MainThread) [supervisor.addons.options] Option 'queue' does not exist in the schema for Zigbee2mqtt Edge (45df7312_zigbee2mqtt_edge)
22-05-11 19:27:15 WARNING (MainThread) [supervisor.addons.options] Option 'frontend' does not exist in the schema for Zigbee2mqtt Edge (45df7312_zigbee2mqtt_edge)
22-05-11 19:27:15 WARNING (MainThread) [supervisor.addons.options] Option 'experimental' does not exist in the schema for Zigbee2mqtt Edge (45df7312_zigbee2mqtt_edge)
22-05-11 19:27:15 WARNING (MainThread) [supervisor.addons.options] Option 'availability' does not exist in the schema for Zigbee2mqtt Edge (45df7312_zigbee2mqtt_edge)
22-05-11 19:27:15 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
22-05-11 19:27:15 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-05-11 19:27:16 INFO (MainThread) [supervisor.host.services] Updating service information
22-05-11 19:27:16 INFO (MainThread) [supervisor.host.network] Updating local network information
22-05-11 19:27:17 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-05-11 19:27:17 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-05-11 19:27:17 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-05-11 19:27:17 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-05-11 19:27:19 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-05-11 19:27:19 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-05-11 19:27:19 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
22-05-11 19:27:21 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt_user'
22-05-11 19:27:21 INFO (MainThread) [supervisor.auth] Successful login for 'mqtt_user'
22-05-11 19:27:43 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
22-05-11 19:27:43 INFO (MainThread) [supervisor.api.proxy] WebSocket access from core_almond
22-05-11 19:27:43 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
22-05-11 19:29:11 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from a0d7b954_ssh
22-05-11 19:29:11 INFO (MainThread) [supervisor.api.middleware.security] /host/info access from a0d7b954_ssh
22-05-11 19:29:11 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from a0d7b954_ssh
22-05-11 19:30:05 INFO (MainThread) [supervisor.api.middleware.security] /core/logs access from a0d7b954_ssh
22-05-11 19:30:25 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:30:25 WARNING (MainThread) [supervisor.addons.options] Option 'external_converters' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:30:25 WARNING (MainThread) [supervisor.addons.options] Option 'devices' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:30:25 WARNING (MainThread) [supervisor.addons.options] Option 'groups' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:30:25 WARNING (MainThread) [supervisor.addons.options] Option 'homeassistant' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:30:25 WARNING (MainThread) [supervisor.addons.options] Option 'permit_join' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:30:25 WARNING (MainThread) [supervisor.addons.options] Option 'advanced' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:30:25 WARNING (MainThread) [supervisor.addons.options] Option 'device_options' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:30:25 WARNING (MainThread) [supervisor.addons.options] Option 'blocklist' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:30:25 WARNING (MainThread) [supervisor.addons.options] Option 'passlist' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:30:25 WARNING (MainThread) [supervisor.addons.options] Option 'queue' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:30:25 WARNING (MainThread) [supervisor.addons.options] Option 'frontend' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:30:25 WARNING (MainThread) [supervisor.addons.options] Option 'experimental' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:30:25 WARNING (MainThread) [supervisor.addons.options] Option 'availability' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-05-11 19:30:25 WARNING (MainThread) [supervisor.addons.options] Unknown option 'password_authentication' for SSH & Web Terminal (a0d7b954_ssh)
22-05-11 19:31:10 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/logs access from a0d7b954_ssh
22-05-11 19:32:05 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/logs access from a0d7b954_ssh
Configuration.yaml:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
influxdb:
host: localhost
port: 8086
database: homeassistant
username: influx_user
password: ################
ssl: false
verify_ssl: false
max_retries: 3
default_measurement: state
- platform: openweathermap_all
api_key: #######################
longitude: 10.0385239
latitude: 53.5734864
