Have installed the addon with home assistant on a Raspberry Pi 3 and followed the configuration steps as described on the addon-node-red github page.
There are no problems in the log when running node red and the web UI login screen is reachable.
When filling in the user name and password and hit the login button. The login screen keeps refreshing and the username and password field are blank again, there were no login errors.
It’s not possible to get pass the login screen.
I tried it with Firefox, Chrome and IE, but with no success.
Has anyone encountered the same problem and found a solution?
Thanks Owi! Perfect!
I’m also using BitDefender and noticed after your comment that it blocked traffic 86 times without any info! (sic!)
By the way I see that there are rumors regarding Hassio, but this time you cannot say hassio fault.
I must say the Home Assistant project is great and hope it will keep on growing!
No antivirus software and no adblock add-on but facing same situation with @Owi . Is there a way to install any packet manager (like apt, yum) to hass to install node-red manually? Or any solution suggestion?
Edit:I couldn’t find a way to add an exception on firefox but, both Chrome and Opera can login to node red.
This issue drove me crazy, kept typing my user and pass from my Node RED config. For some reason this works the first time you load node red. Once you reboot, you need to login to Node RED with your user and pass for your Hass.io install. Giggity! Good luck, hope that helps. Drove me insane for an hour.
This worked for me too! @chenzomo if I hadn’t read this I’d never have guessed to try my hass credentials. Well done for figuring out and for sharing it here
