Hi, i cant seem to get the app working for either android or ios.
I get these lines in the log when i try, i did try with both username (which i never get an option to enter) and trusted networks:
--------------------------8<--------------------------
2019-12-17 09:55:58 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
File "/usr/lib/python3.7/asyncio/sslproto.py", line 625, in _on_handshake_complete
raise handshake_exc
File "/usr/lib/python3.7/asyncio/sslproto.py", line 189, in feed_ssldata
self._sslobj.do_handshake()
File "/usr/lib/python3.7/ssl.py", line 763, in do_handshake
ssl.SSLError: [SSL: SSLV3_ALERT_CERTIFICATE_UNKNOWN] sslv3 alert certificate unknown (_ssl.c:1056)
2019-12-17 09:55:58 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error in data received
File "/usr/lib/python3.7/asyncio/sslproto.py", line 526, in data_received
ssldata, appdata = self._sslpipe.feed_ssldata(data)
2019-12-17 09:56:04 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:45
2019-12-17 09:56:49 ERROR (MainThread) [homeassistant.components.auth.indieauth] Timeout while looking up redirect_uri https://home-assistant.io/android
2019-12-17 09:56:49 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.0.60
2019-12-17 09:56:49 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error in data received
File "/usr/lib/python3.7/asyncio/sslproto.py", line 207, in feed_ssldata
self._sslobj.unwrap()
File "/usr/lib/python3.7/ssl.py", line 767, in unwrap
return self._sslobj.shutdown()
ssl.SSLError: [SSL: KRB5_S_INIT] application data after close notify (_ssl.c:2609)
2019-12-17 09:56:53 ERROR (MainThread) [homeassistant.components.auth.indieauth] Timeout while looking up redirect_uri https://home-assistant.io/android
2019-12-17 09:56:53 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.0.60
2019-12-17 09:57:02 ERROR (MainThread) [homeassistant.components.auth.indieauth] Timeout while looking up redirect_uri https://home-assistant.io/android
2019-12-17 09:57:03 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.0.60
-------------------------->8--------------------------
I have a working ssl certificate and it has not expired.
I have my own DNS so i use the same port and hostname (ie: mydomain.com:XXXX) both locally and externally and its working great in chrome, but not in the app.
I have both discovery and mobile_app added in configuration.
The HA is installed on debian 10 in a venv further relevant specs below:
arch | x86_64 |
dev | false |
docker | false |
hassio | false |
os_name | Linux |
python_version | 3.7.3 |
timezone | Europe/Stockholm |
version | 0.102.3 |
virtualenv | true |
I have tried and disabled IPV6 but no avail. I can ping and surf to home-assistant.io from the debian machine without any problem with both IPV6 on and off.
Sooo…what im i doing wrong?
I would REALLY appreciate any help i can get!
