Cant login to HA locally with Safari
I aim running HA OS10.5 for 2023,8.4 ib a linuX virtual machine under VirtualBox on MacOSX 12.6.2
I am unable ti login in using Safari. I get invalid username or password error.
The log give the following arror
  • Login attempt or request with invalid authentication from 10.0.1.175 (10.0.1.175). Requested URL: ‘/auth/login_flow/79f85280a5b84a1bc6b298e1c37ec77d’. (Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.5.2 Safari/605.1.15)
I can log on with same credentials using Firefox.
Any suggestions? This only started occurring sense my las core and OS updated
It’s a known problem with Safari, you can reload all your cache and it will work. For me I just stopped using Safari for HA. There’s also now the companion app that runs as a native MacOS app if you want to go that route.
I am tryting to make use of Browser Mod as a media player so native app doesn’t help
You can login in HA with Safari but it only works when you type username and passwort manually in the fields. It doesnt work when you use auto fill in.
before I cleared the caches. it didn’t work. afterwards. you are right thanks.
