I’ve recently acquired a Samsung Galaxy Tab A6 to use as a smart home dashboard. However, upon installing the HA app, I’m can’t get it to show me the login screen after I enter the URL. It just shows this:
What can I do to fix this issue?
turn of your WIFI on your phone ! or restart ur phone…your site is there …so please also remove/delete your picture again ![]()
You are exposing your url !
check that android system webview is fully upto date in the play store
This indeed turned out to be the issue. It’s fixed now, thank you!
A little late on this topic but have the same issue. Any idea on a Fire tablet without (an easy) way to update the android system webview?
So I had the same issue, however it looks like I’m on the latest version or maybe I just can’t update.
My resolve was to disable System Webview and it then started working.
@dshokouhi if you go to Setting → Apps and then open systems apps you should then be able to disable System Webview, you can always re-enable if it does not work.
googles own documentation goes against this advice
Very true, but it does work and as I only use my tablet for Home Assistant I’m not sure that it matters.
I have the same problem but in reverse, my android still works but my pc chrome or edge only has a HA logo and i can’t login.
I tried updating my android system webview but still it facing with the same problem in my android device, do anybody have solution for this?
do you see a blank white page like teh screenshot or something else? If you see a blank white page are you by chance using a self signed certificate?
no i am trying out it in my localhost, so that I 'm not using SSL here, do you have any solutions for this , only home assistant logo is coming for my android app login page, i tried updating Android System Webview, but no use, do you have any other methods to mitigate this issue?
I have the same issue on Chrome Desktop. What could be going on with the HA setup? I’m running a Pi5 with SSD on a HAT and SonOff Zigbee dongle.
