Can't Loop Script
Hi Guys,
I am trying to loop a script.
I first followed the example of the flashing lights scripts in the documentation but later found in the forums that a script calling itself is no longer supported.
I found a later example that contained two scripts, one to do the thing and another to call the first. I must be stupid because I cant work out why it doesn’t want to work for me when everyone else has success.
When running the script, I get an error of [homeassistant.components.script] Script script.weatherset already running.
Can you help me in the right direction?
> weatherset:
>     alias: "Set Weather Cube"
>     sequence:
>       - alias: "Set Weather"
>         service: shell_command.cube_clear
>       - delay:
>           seconds: 31
>       - alias: "Loop weather"
>         service: script.turn_on
>         data:
>           entity_id: script.weatherloop
> weatherloop:
>      alias: "Loop Weather Cube"
>      sequence:
>      - service: script.turn_on
>        data:
>           entity_id: script.weatherset
Anybody? I’m so stuck on this one!
Not sure I’ve got your answer, but a couple things to try.
  1. In the weatherloop script, try adding a short delay before the script.turn_on service. Not sure if things run asynchronously.
  2. In weatherloop, try adding a script.turn_off for weatherset before you try the script.turn_on. So basically, stop and restart it. You might insert a bit of delay between off and on, spreading that 31 seconds between the three positions.
Brilliant. That seems to work! Thank you so much!
Was it suggestion one or two? (for future visitors to this thread)
I did both, seemed cleaner to stop the script and to give the next one a delay before it tried to start the previous script again.
