Can't modify ZHA device type or access all attributes
I have an RGB light strip that I’m trying to control with HA. It’s a QV-RGBCCT by Quotra-Vision. It’s showing up as a router, and not all of the attributes and capabilities are showing up.
I followed the tutorial, but it has no effect.
How do I get this working?
Here are the device parameters.
Zigbee Info
IEEE: 00:12:4b:00:1a:b0:15:2b
Nwk: 0x84ab
Device Type: Router
LQI: 21
RSSI: Unknown
Last Seen: 2023-03-22T22:21:00
Power Source: Mains
Here’s what shows up in the signature.
  "node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=0, maximum_buffer_size=80, maximum_incoming_transfer_size=160, server_mask=0, maximum_outgoing_transfer_size=160, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
  "endpoints": {
    "11": {
      "profile_id": 260,
      "device_type": "0x0210",
      "in_clusters": [
        "0x0000",
        "0x0003",
        "0x0004",
        "0x0005",
        "0x0006",
        "0x0008",
        "0x0300"
      "out_clusters": []
    "13": {
      "profile_id": 49246,
      "device_type": "0xe15e",
      "in_clusters": [
        "0x1000"
      "out_clusters": [
        "0x1000"
  "manufacturer": "Quotra-Vision",
  "model": "QV-RGBCCT",
  "class": "zigpy.device.Device"
All of the light attributes are showing up in the debug output.
  "home_assistant": {
    "installation_type": "Home Assistant Container",
    "version": "2023.3.5",
    "dev": false,
    "hassio": false,
    "virtualenv": false,
    "python_version": "3.10.10",
    "docker": true,
    "arch": "x86_64",
    "timezone": "America/Detroit",
    "os_name": "Linux",
    "os_version": "5.15.0-67-generic",
    "run_as_root": true
  "custom_components": {},
  "integration_manifest": {
    "domain": "zha",
    "name": "Zigbee Home Automation",
    "after_dependencies": [
      "onboarding",
      "usb"
    "codeowners": [
      "@dmulcahey",
      "@adminiuga",
      "@puddly"
    "config_flow": true,
    "dependencies": [
      "file_upload"
    "documentation": "https://www.home-assistant.io/integrations/zha",
    "iot_class": "local_polling",
    "loggers": [
      "aiosqlite",
      "bellows",
      "crccheck",
      "pure_pcapy3",
      "zhaquirks",
      "zigpy",
      "zigpy_deconz",
      "zigpy_xbee",
      "zigpy_zigate",
      "zigpy_znp"
    "requirements": [
      "bellows==0.34.10",
      "pyserial==3.5",
      "pyserial-asyncio==0.6",
      "zha-quirks==0.0.94",
      "zigpy-deconz==0.19.2",
      "zigpy==0.53.2",
      "zigpy-xbee==0.16.2",
      "zigpy-zigate==0.10.3",
      "zigpy-znp==0.9.3"
    "usb": [
        "vid": "10C4",
        "pid": "EA60",
        "description": "*2652*",
        "known_devices": [
          "slae.sh cc2652rb stick"
        "vid": "1A86",
        "pid": "55D4",
        "description": "*sonoff*plus*",
        "known_devices": [
          "sonoff zigbee dongle plus v2"
        "vid": "10C4",
        "pid": "EA60",
        "known_devices": [
          "sonoff zigbee dongle plus"
        "vid": "10C4",
        "pid": "EA60",
        "description": "*tubeszb*",
        "known_devices": [
          "TubesZB Coordinator"
        "vid": "1A86",
        "pid": "7523",
        "known_devices": [
        "vid": "1A86",
        "pid": "7523",
        "description": "*zigstar*",
        "known_devices": [
          "ZigStar Coordinators"
        "vid": "1CF1",
        "pid": "0030",
        "description": "*conbee*",
        "known_devices": [
          "Conbee II"
        "vid": "10C4",
        "pid": "8A2A",
        "description": "*zigbee*",
        "known_devices": [
          "Nortek HUSBZB-1"
        "vid": "0403",
        "pid": "6015",
        "description": "*zigate*",
        "known_devices": [
          "ZiGate+"
        "vid": "10C4",
        "pid": "EA60",
        "known_devices": [
          "ZiGate"
        "vid": "10C4",
        "pid": "8B34",
        "description": "*bv 2010/10*",
        "known_devices": [
          "Bitron Video AV2010/10"
    "zeroconf": [
        "type": "_esphomelib._tcp.local.",
        "name": "tube*"
        "type": "_zigate-zigbee-gateway._tcp.local.",
        "name": "*zigate*"
        "type": "_zigstar_gw._tcp.local.",
        "name": "*zigstar*"
        "type": "_slzb-06._tcp.local.",
        "name": "slzb-06*"
    "is_built_in": true
  "data": {
    "ieee": "**REDACTED**",
    "nwk": 33963,
    "name": "Quotra-Vision QV-RGBCCT",
    "quirk_applied": false,
    "quirk_class": "zigpy.device.Device",
    "manufacturer_code": 0,
    "power_source": "Mains",
    "lqi": 25,
    "rssi": null,
    "last_seen": "2023-03-22T22:21:53",
    "available": true,
    "device_type": "Router",
    "signature": {
      "endpoints": {
        "11": {
          "profile_id": 260,
          "in_clusters": [
            "0x0000",
            "0x0003",
            "0x0004",
            "0x0005",
            "0x0006",
            "0x0008",
            "0x0300"
          "out_clusters": []
        "13": {
          "in_clusters": [
            "0x1000"
          "out_clusters": [
            "0x1000"
    "active_coordinator": false,
    "entities": [
        "entity_id": "button.quotra_vision_qv_rgbcct_identify",
        "entity_id": "switch.quotra_vision_qv_rgbcct_switch",
    "neighbors": [],
    "routes": [],
    "endpoint_names": [
        "name": "undefined_0x0210"
        "name": "undefined_0xe15e"
    "user_given_name": "Headboard Light",
    "device_reg_id": "49d51b681bf733d615f609b24dca3297",
    "area_id": "bedroom",
    "cluster_details": {
      "11": {
        "device_type": {
          "name": "undefined_0x0210",
          "id": 528
        "profile_id": 260,
        "in_clusters": {
          "0x0000": {
            "endpoint_attribute": "basic",
            "attributes": {
              "0x0004": {
                "attribute_name": "manufacturer",
                "value": "Quotra-Vision"
              "0x0005": {
                "attribute_name": "model",
                "value": "QV-RGBCCT"
            "unsupported_attributes": {
              "0x0008": {
                "attribute_name": "generic_device_class"
              "0x0009": {
                "attribute_name": "generic_device_type"
              "0x000a": {
                "attribute_name": "product_code"
              "0xfffe": {
                "attribute_name": "attr_reporting_status"
              "0x0013": {
                "attribute_name": "alarm_mask"
          "0x0003": {
            "endpoint_attribute": "identify",
            "attributes": {},
            "unsupported_attributes": {}
          "0x0004": {
            "endpoint_attribute": "groups",
            "attributes": {},
          "0x0005": {
            "endpoint_attribute": "scenes",
            "attributes": {},
          "0x0006": {
            "endpoint_attribute": "on_off",
            "attributes": {
              "0x0000": {
                "attribute_name": "on_off",
                "value": 0
              "0x4003": {
                "attribute_name": "start_up_on_off"
          "0x0008": {
            "endpoint_attribute": "level",
            "attributes": {
              "0x0000": {
                "attribute_name": "current_level",
                "value": 254
              "0x4000": {
                "attribute_name": "start_up_current_level"
              "0x0011": {
                "attribute_name": "on_level"
              "0x0012": {
                "attribute_name": "on_transition_time"
              "0x0014": {
                "attribute_name": "default_move_rate"
              "0x0010": {
                "attribute_name": "on_off_transition_time"
              "0x0013": {
                "attribute_name": "off_transition_time"
          "0x0300": {
            "endpoint_attribute": "light_color",
            "attributes": {
              "0x0000": {
                "attribute_name": "current_hue",
                "value": 0
              "0x0001": {
                "attribute_name": "current_saturation",
                "value": 0
              "0x0003": {
                "attribute_name": "current_x",
                "value": 20480
              "0x0004": {
                "attribute_name": "current_y",
                "value": 21845
              "0x0007": {
                "attribute_name": "color_temperature",
                "value": 268
              "0x0008": {
                "attribute_name": "color_mode",
                "value": 2
              "0x4000": {
                "attribute_name": "enhanced_current_hue",
                "value": 0
              "0x4002": {
                "attribute_name": "color_loop_active",
                "value": 0
              "0x400a": {
                "attribute_name": "color_capabilities",
                "value": 31
              "0x4010": {
                "attribute_name": "start_up_color_temperature"
              "0xfffe": {
              "0x400b": {
                "attribute_name": "color_temp_physical_min"
              "0x400c": {
                "attribute_name": "color_temp_physical_max"
              "0x000f": {
                "attribute_name": "options"
        "out_clusters": {}
      "13": {
        "device_type": {
          "name": "undefined_0xe15e",
          "id": 57694
        "in_clusters": {
          "0x1000": {
            "endpoint_attribute": "lightlink",
            "attributes": {},
        "out_clusters": {
          "0x1000": {
            "attributes": {},
Not exactly…
And in this context the first entry - device_type:router refers to the fact that the device repeats messages on the Zigbee network
You’re interested in the SECOND instance “device_type”: “0x0210” That basically translate to ZLL Color (RGBCCT) (Which what I see about your device - QV-RGBCCT by Quotra-Vision) is correct.
So what exactly ‘isn’t showing up’ and where? Can you see the device in the device list? what entities are exposed?
Great! One problem down!
The device shows up, but the only things I can control are on/off and the “identify” button. I can’t control the dimmer, color temperature, hue, etc.
Capture
