I have two ONVIF cameras. They worked fine until some recent release. I can’t tell precisely after which update they stopped working.
Currently I’m running 0.114.1. I can see the picture from the camera (using lovelace widget). But I can’t open video stream anymore. Here is the error:
Logger: root
Source: components/stream/worker.py:49
First occurred: 12:40:43 AM (10 occurrences)
Last logged: 2:02:00 PM
Uncaught thread exception
File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner
self.run()
File "/usr/local/lib/python3.8/threading.py", line 870, in run
self._target(*self._args, **self._kwargs)
File "/usr/src/homeassistant/homeassistant/components/stream/worker.py", line 49, in stream_worker
container = av.open(stream.source, options=stream.options)
File "av/container/core.pyx", line 354, in av.container.core.open
File "av/container/core.pyx", line 225, in av.container.core.Container.__cinit__
File "av/container/core.pyx", line 257, in av.container.core.Container.err_check
File "av/error.pyx", line 336, in av.error.err_check
av.error.OSError: [Errno 5] I/O error: 'rtsp://admin:[stripped]@192.168.1.139:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif'; last error log: [tcp] Failed to resolve hostname admin: Try again
