0.87.1 running on Rpi in Docker container
Assuming this documentation on the Rainmachine component is current: https://www.home-assistant.io/components/rainmachine/ I find I am unable to override the default 600 second zone run time. At startup the zone switches are populated correctly, no log errors are reported, but turning on a switch runs the zone for the component’s default 10 minutes, not 15.
–configuration.yaml–
rainmachine:
controllers:
- ip_address: 192.168.1.175
password: xxxxxxx
switches:
zone_run_time: 900
I don’t know if this worked once upon a time or if it broke in 0.87…
Suggestions welcome… .thanks.
