Can't pair a Hue dimmer in zigbee2mqtt
I have a KVM based Hassio with host shared Deconz Conbee II USB.
I installed Zigbee2MQTT and based on these logs it connects properly to /dev/ttyACM0
See the logs:
Zigbee2MQTT:info  2022-06-17 20:43:48: Starting zigbee-herdsman (0.14.34)
Zigbee2MQTT:debug 2022-06-17 20:43:48: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/config/zigbee2mqtt/coordinator_backup.json","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","databasePath":"/config/zigbee2mqtt/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"adapter":"deconz","path":"/dev/ttyACM0"}}'
CREATED DECONZ ADAPTER
Zigbee2MQTT:info  2022-06-17 20:43:49: zigbee-herdsman started (resumed)
Zigbee2MQTT:info  2022-06-17 20:43:49: Coordinator firmware version: '{"meta":{"maintrel":0,"majorrel":38,"minorrel":114,"product":0,"revision":"0x26720700","transportrev":0},"type":"ConBee2/RaspBee2"}'
Zigbee2MQTT:debug 2022-06-17 20:43:49: Zigbee network parameters: {"channel":11,"extendedPanID":"0xdddddddddddddddd","panID":6754}
Zigbee2MQTT:info  2022-06-17 20:43:49: Currently 0 devices are joined:
Zigbee2MQTT:warn  2022-06-17 20:43:49: `permit_join` set to  `true` in configuration.yaml.
Zigbee2MQTT:warn  2022-06-17 20:43:49: Allowing new devices to join.
Zigbee2MQTT:warn  2022-06-17 20:43:49: Set `permit_join` to `false` once you joined all devices.
Zigbee2MQTT:info  2022-06-17 20:43:49: Zigbee: allowing new devices to join.
Zigbee2MQTT:info  2022-06-17 20:43:50: Connecting to MQTT server at mqtt://core-mosquitto:1883
Zigbee2MQTT:debug 2022-06-17 20:43:50: Using MQTT login with username: addons
Zigbee2MQTT:info  2022-06-17 20:43:50: Connected to MQTT server
The problem is that when I permit to join other devices, also following the device dedicated pairing instructions, nothing happens:
No sign of life in the logs neither.
Any clue what how to troubleshoot or perhaps you’ve seen this before?
