I’m trying to connect my Ikea Skydrag light strip to HA, but it’s not working. I’ve searched the forums here, reddit, and elsewhere and can’t find a solution.
My setup:
Ikea Skydrag light strip plugged into a Tradfri driver
SkyConnect plugged into HA Green via USB extension cable
What I’ve tried:
Turning toggling the power to the Tradfri driver on/off 6 times in 1 second intervals and clicking to start searching for devices right before the last on/off cycle
Doing above while the light strip is in Auto and On modes
putting the SkyConnect dongle right next to the Tradfri driver
I was able to connect an Aqara mini switch via SkyConnect
For the IKEA Driver, you need to use a paper clip to press the reset button on the device for 6+ seconds or until the attached strip pulses on and off a couple of times. Then it will be in pairing mode. The Driver doesn’t respond to power on/off toggling.
