Found the perfect wall light switch: a Wulian WL-ZCSWNPW-S1322-01 (http://www.wuliangroup.com/en/site/productdetail/527) however can’t seem to pair it at all. I’m using a tasmotized Sonoff Zbridge.
Here’s the log.
Although it “joins” the network it always ends in a failure.Anyone have any experience with this product by any chance?
[0x0000:zdo] ZDO request ZDOCmd.Mgmt_Permit_Joining_req: [60, <Bool.false: 0>]
[0x9b68:1:0x0402] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=120 command_id=Command.Report_Attributes>
[0x9b68:1:0x0402] ZCL request 0x000a: [[Attribute(attrid=0, value=<TypeValue type=int16s, value=2096>)]]
[0x9b68:1:0x0402] Attribute report received: measured_value=2096
Device 0x40bb (00:12:4b:00:0f:6c:33:21) joined the network
[0x40bb] Requesting 'Node Descriptor'
Tries remaining: 2
[0x40bb] Extending timeout for 0x51 request
[0x40bb] Delivery error for seq # 0x51, on endpoint id 0 cluster 0x0002: message send failure
Tries remaining: 1
[0x40bb] Extending timeout for 0x53 request
[0x40bb] Delivery error for seq # 0x53, on endpoint id 0 cluster 0x0002: message send failure
[0x40bb] Requesting Node Descriptor failed
[0x40bb] Discovering endpoints
Tries remaining: 3
[0x40bb] Extending timeout for 0x55 request
[0x40bb] Delivery error for seq # 0x55, on endpoint id 0 cluster 0x0005: message send failure
Tries remaining: 2
[0x40bb] Extending timeout for 0x57 request
[0x40bb] Delivery error for seq # 0x57, on endpoint id 0 cluster 0x0005: message send failure
Tries remaining: 1
[0x40bb] Extending timeout for 0x59 request
[0x40bb] Delivery error for seq # 0x59, on endpoint id 0 cluster 0x0005: message send failure
[0x40bb] Failed to discover active endpoints
[0x9b68:1:0x0405] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=121 command_id=Command.Report_Attributes>
[0x9b68:1:0x0405] ZCL request 0x000a: [[Attribute(attrid=0, value=<TypeValue type=uint16_t, value=6818>)]]
[0x9b68:1:0x0405] Attribute report received: measured_value=6818
