Thanks for that - and indeed that work (got triggered). But sadly, the evo home didn’t adjust.I'm starting to suspect the integration has issues. It now works…
If I “call service” from the service tab under “developer tools” - with the example data - it triggers errors.
For reference, your code got reformatted by the UI to this which works:
I did a compare with what was “my error” and it’s the 2 spaces I had to add under “entity_id”
What is weird is I use hassio, and use the UI most of the time for scripts. It’s the UI that generated the wrong code. I’m not competent enought in code to understand why but that’s that. And evohome was being a princess on me and worked after some time.
Cheers.
