Can't play a playlist in Spotify media player
I just setup the Spotify integration following the documentation.
When I try to play a playlist through the documentation’s example with the play_media service and the playlist URI I get the following error:
Jan 27 00:46:23 raspberrypi hass[28278]: 2020-01-27 00:46:23 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.2866991632] unsupported operand type(s) for &: 'NoneType' and 'int'
Jan 27 00:46:23 raspberrypi hass[28278]: Traceback (most recent call last):
Jan 27 00:46:23 raspberrypi hass[28278]:   File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/websocket_api/commands.py", line 133, in handle_call_service
Jan 27 00:46:23 raspberrypi hass[28278]:     connection.context(msg),
Jan 27 00:46:23 raspberrypi hass[28278]:   File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/core.py", line 1236, in async_call
Jan 27 00:46:23 raspberrypi hass[28278]:     await asyncio.shield(self._execute_service(handler, service_call))
Jan 27 00:46:23 raspberrypi hass[28278]:   File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/core.py", line 1261, in _execute_service
Jan 27 00:46:23 raspberrypi hass[28278]:     await handler.func(service_call)
Jan 27 00:46:23 raspberrypi hass[28278]:   File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity_component.py", line 213, in handle_service
Jan 27 00:46:23 raspberrypi hass[28278]:     self._platforms.values(), func, call, service_name, required_features
Jan 27 00:46:23 raspberrypi hass[28278]:   File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/service.py", line 348, in entity_service_call
Jan 27 00:46:23 raspberrypi hass[28278]:     future.result()  # pop exception if have
Jan 27 00:46:23 raspberrypi hass[28278]:   File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/service.py", line 363, in _handle_service_platform_call
Jan 27 00:46:23 raspberrypi hass[28278]:     entity.supported_features & feature_set for feature_set in required_features
Jan 27 00:46:23 raspberrypi hass[28278]:   File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/service.py", line 363, in <genexpr>
Jan 27 00:46:23 raspberrypi hass[28278]: TypeError: unsupported operand type(s) for &: 'NoneType' and 'int'
You’ll need to post your service call.
I call the service media_player.play_media from the Services tab under Developers Tools, with the following data, following the documentation’s example:
entity_id: media_player.spotify
media_content_type: playlist
media_content_id: spotify:user:spotify:playlist:37i9dQZF1DWSkkUxEhrBdF
