hi,
the spotify integration seems to work (no errror and “detects” a spotify premium)
so i tried a simple script:
spotitest:
alias: 'Playlist'
sequence:
- service: media_player.play_media
data_template:
entity_id: media_player.hobbyraum
media_content_id: 'spotify:user:spotify:playlist:2jzSk9JuA1aikOVUZFfXFf'
media_content_type: 'playlist'
media_player.hobbyraum is a google home wich make the “activated sound” when i run the script and nothing more
Fuzzysteve
(FuzzySteve)
2
From an automation I have. (it’s a touch problematic. still tinkering with it.)
- service: media_player.select_source
entity_id: media_player.spotify_myusernamehere
source: asourcefromSpotify
media_content_id: spotify:playlist:5YLZml89bXSdsfdsotNy
media_content_type: playlist
the spotify playlist uri I got from a right click on the playlist, share, copy spotify uri.
The source selection I can see in the spotify card
i want to use the speaker as playback device, so that wont work, sorry ![:frowning: :frowning:](https://community.home-assistant.io/images/emoji/twitter/frowning.png?v=9)
Fuzzysteve
(FuzzySteve)
4
If you can use the speaker with spotify, it’ll be there. Or should be. My echo dots show up. That’s what the select_source is for.
Doing a little research
It looks like you can’t cast using spotify connect, which is what this uses.
