Can't PTZ control YOOSEE IP Camera
Hi, I have 5 YOOSEE PTZ IP cameras:
those are working with Android YooSee application and known as yoosee cameras. Cameras capable of streaming 2 main video and audio streams:
  1. hires main stream: rtsp://<camera_ip>:554/onvif1
  2. lowres substream: rtsp://<camera_ip>:554/onvif2
Onvif port for PTZ control is 5000.
Another thing is, those are UDP (not TCP) streams and I have tried many ways to get the to display video including onvif:
- platform: onvif
  host: 192.168.x.x
  username: admin
  password: verysecret
  port: 5000
  extra_arguments: -rtsp_transport udp
and mjpeg:
  - platform: ffmpeg
    input: rtsp://192.168.1.xxx:554/onvif1
with extra parameters like tcp_transport udp and without non of them working.
The only way worked is through motioneye plugin installed through supervisor panel in HA.
I have got YCC365 camera to work with the following card in lovelace:
type: picture-elements
title: Hall PTZ Camera
camera_image: camera.hall_camera
elements:
  - type: state-icon
    tap_action:
      action: call-service
      service: ptz_camera.move_left
      service_data:
        host: '192.168.1.12'
    entity: camera.hall_camera
    icon: 'mdi:arrow-left-drop-circle'
    style:
      bottom: 45%
      left: 5%
      color: white
      opacity: 0.5
      transform: ' scale (1.5, 1.5) '
  - type: state-icon
    tap_action:
      service: ptz_camera.move_right
      service_data:
    icon: 'mdi:arrow-right-drop-circle'
    style:
      bottom: 45%
      right: 5%
      color: white
      opacity: 0.5
  - type: state-icon
    tap_action:
      service: ptz_camera.move_up
      service_data:
    icon: 'mdi:arrow-up-drop-circle'
    style:
      top: 10%
      left: 46%
      color: white
      opacity: 0.5
  - type: state-icon
    tap_action:
      service: ptz_camera.move_down
      service_data:
    icon: 'mdi:arrow-down-drop-circle'
    style:
      bottom: 10%
      left: 46%
      color: white
      opacity: 0.5
  - type: state-icon
    tap_action:
      action: more-info
    icon: 'mdi:arrow-expand-all'
    style:
      top: 5%
      right: 5%
      color: white
      opacity: 0.5
camera_view: live
But I can’t figure out how to get yoosee PTZ to work.
I changed code and added port:
elements:
  - type: state-icon
    tap_action:
      service_data:
        host: '192.168.1.12:5000'
    style:
      bottom: 45%
      left: 5%
      color: white
      opacity: 0.5
  - type: state-icon
    tap_action:
      service_data:
    style:
      bottom: 45%
      right: 5%
      color: white
      opacity: 0.5
  - type: state-icon
    tap_action:
      service_data:
    style:
      top: 10%
      left: 46%
      color: white
      opacity: 0.5
  - type: state-icon
    tap_action:
      service_data:
    style:
      bottom: 10%
      left: 46%
      color: white
      opacity: 0.5
  - type: state-icon
    tap_action:
      action: more-info
    style:
      top: 5%
      right: 5%
      color: white
      opacity: 0.5
camera_view: live
However it throws the following error when I try to control camera:
Logger: homeassistant.components.websocket_api.http.connection
Source: custom_components/ptz_camera/__init__.py:34
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 6:05:38 PM (1 occurrences)
Last logged: 6:05:38 PM
[1771407032] ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 699, in urlopen
    httplib_response = self._make_request(
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 445, in _make_request
    six.raise_from(e, None)
  File "<string>", line 3, in raise_from
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 440, in _make_request
    httplib_response = conn.getresponse()
  File "/usr/local/lib/python3.8/http/client.py", line 1347, in getresponse
    response.begin()
  File "/usr/local/lib/python3.8/http/client.py", line 307, in begin
    version, status, reason = self._read_status()
  File "/usr/local/lib/python3.8/http/client.py", line 276, in _read_status
    raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
  File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 439, in send
    resp = conn.urlopen(
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 755, in urlopen
    retries = retries.increment(
  File "/usr/local/lib/python3.8/site-packages/urllib3/util/retry.py", line 531, in increment
    raise six.reraise(type(error), error, _stacktrace)
  File "/usr/local/lib/python3.8/site-packages/urllib3/packages/six.py", line 734, in reraise
    raise value.with_traceback(tb)
    response.begin()
urllib3.exceptions.ProtocolError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 141, in handle_call_service
    await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1488, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1527, in _execute_service
    await self._hass.async_add_executor_job(handler.job.target, service_call)
  File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
  File "/config/custom_components/ptz_camera/__init__.py", line 82, in move_right
    stop(call)
  File "/config/custom_components/ptz_camera/__init__.py", line 34, in stop
    r = requests.post('http://'+host+'/onvif/PTZ', data=xml, headers=DEFAULT_HEADERS)
  File "/usr/local/lib/python3.8/site-packages/requests/api.py", line 119, in post
    return request('post', url, data=data, json=json, **kwargs)
  File "/usr/local/lib/python3.8/site-packages/requests/api.py", line 61, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 542, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 655, in send
    r = adapter.send(request, **kwargs)
  File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 498, in send
    raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
I’m using the following custom component for PTZ control: ptz_camera to send onvif ptz xml
Can somebody help?
thanks
I have faced the same problem as you.
I do not know if you still need it or not, but it may be useful for other people.
I have modified the original custom component ptz_camera in a fork working for YCC365, Y05 and YOOSEE cameras.
PTZ-YALL
I’m facing this problem too with yoosee cam and followed the readme. But I’m stucked at GitHub - carvalr/PTZ-YALL: Fork of PTZ-YCC365 because I tried adding with motionEye (surveillance_username & password I don’t have), mjpeg (No connection) and /config/configuration.yaml code (maybe wrong port?)
ptz_camera:
  camera:
    - platform: mjpeg
      mjpeg_url: http://192.168.178.42:8083
Non of it worked… I see a empty card. Anyone had luck with it? rtsp://192.168.178.42:554/onvif1 works and ONVIF Device Manager too.
