docker pull homeassistant/home-assistant
I’ve tried getting this image various ways pulled as above
docker run, docker-compose but I keep getting the same error message.
Error response from daemon: Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io on [::1]:53: read udp [::1]:42869->[::1]:53: read: connection refused
I’ve seen an error similar to this around the web. I think they typically change DNS settings and it fixes it. Obviously, the process differs from OS to OS.
Hi thanks for your reply I had seen this as well and changed my dns from 1.1.1.1 back to 8.8.8.8
but still the same . Plus i can get any other image , the problem just seems to be with the home assistant image. But I’ll try few more dns changes to see if that works.
I had a similar problem on portainer, which seems to struggle with large images. If you do a docker pull that will work, I eventually installed watchtower to do it for me
Thanks I just had another go and it’s came in find . Beginning to think the repository was down
for maintenance or something. I’ll have a look at Watchtower.
