Was having trouble with the phone app… I uninstall from the phone, delete from the integration… now it doesn’t show there…
I reinstall the app… and it just connects up! as if nothing ever happened… but … it doesn’t show up in the mobile phone integration! It’s not a device that’s recognized… there’s no device_tracker entry. What do I do to get the phone registered?
Also just noticed that when I reinstall it and it connects up on its own… it seems to have the Device Name the same as my old phone! So I think google is doing something dumb where it’s restoring old config files when I install the app?
But then, if I go in and delete all the data from settings > apps in android… then the next time I run it it tries to onboard, but when I click the instance it just hangs… nothing happens, the onboarding doesn’t occur. The only thing that works is uninstall the app and reinstall and then it magically reconnects.
" * Open known_devices.yaml and delete the (probably last) entry consisting of a 32-character unique ID, representing the device_tracker of your device. This step may not be necessary as the entity may already be removed after step 3."
I don’t find a known_devices.yaml file anywhere? where should that be?
I think honestly the phone is deleted from home assistant now. I can’t find any trace of it… But I can’t re-onboard either… After entering my URL or just clicking on teh discovered instance… it goes to a blank screen an stays there forever
