I cant seem to get the class template to read a different sensor’s state to decide the class that should be used.
I have 2 sensors sensor.dogs_last_fed and sensor.dogsneedfood sensor.dogs_last_fed is simply a timestamp of the last time the dash button was pressed, while dogsneedfood is a timer whose state will be 0, 1 or 2 (increases based on how long since they last ate. The idea is to turn the background orange or red the longer they go without being fed.
Config:
- name: DogFedTimestamp entities: - sensor.dogs_last_fed text_template: 'Dogs last fed: ${entity.state ? entity.state : "unknown"}' class_template: ' if (is_state(sensor.dogsneedfood, 0)) return "green-background"; else if (is_state(sensor.dogsneedfood, 1)) return "orange-background"; else if (is_state(sensor.dogsneedfood, 2)) return "red-background"; '
Some formattings of the template will end up outputting the entire thing as a class but most will result in a error like this:
Uncaught SyntaxError: Unexpected identifier
URL: https://MYDOMAIN/floorplan
Line: 3, column: 5
Error: {}
