While installing the Blink integration, the 2FA pin took a long time to appear, so I skipped that step (thinking I could start over and try again). I didn’t see an option that might re-trigger the 2FA, so I tried to delete the integration. No luck. There were two integration entities. I deleted one. The second has an option to delete it, but it doesn’t appear to do anything. I’m left with a zombie integration.
Next, I tried re-installing the Blink integration. After entering my username and password, the next dialog prompt comes up empty (where it should be asking for 2FA info).
Dear Sir, I am facing the same issue with the blink integration. I also accidentally skipped the 2FA and I am not able to reconfigure the blink integration anymore.
How and where can I find “.storage/core.config_entries” you mentioned?
When I use the “file editor” integration in HA, I can see the yaml files and custom components e.g., but I do not see “.storage/core.config_entries”.
Or do I have to use the SSH terminal? I am running home assistant OS on Windows in a virtual box…
