I have 3 wled devices.
I “configured” their corresponding integrations and they were fine.
I realized I had not set the name of one of them from the default “wled” so all the entity names were wrong. So I changed the name in wled and then tried to reload the corresponding integration for that device. It gave errors for all the entities. So I removed the integration and and restarted the device and then tried to “configure” it again and now it can’t. Pops “unknown error” The error message is not helpful. The log is below. Everything is current, hasso, core and supervisor.
I restarted the core, restarted hassos, restarted the device nothing seems to clear the issue. I even removed one of the other wled integrations and configured it again, no problem.
It’s only related to this one device and it’s all based on the mac address so I can’t “spoof” ha into thinking it’s a new device. Seems like some “crud” ha ha has been left in the database. Can one directly inspect the database?
Suggestions on what to try next…thx
2021-12-11 15:39:44 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 220, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 78, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 181, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 137, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 157, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 62, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 252, in async_configure
result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 325, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/wled/config_flow.py", line 66, in async_step_zeroconf_confirm
return await self._handle_config_flow(user_input)
File "/usr/src/homeassistant/homeassistant/components/wled/config_flow.py", line 91, in _handle_config_flow
device = await wled.update()
File "/usr/local/lib/python3.9/site-packages/backoff/_async.py", line 133, in retry
ret = await target(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/wled/wled.py", line 241, in update
presets = await self.request("/presets.json")
File "/usr/local/lib/python3.9/site-packages/wled/wled.py", line 202, in request
response_data = await response.json()
File "/usr/local/lib/python3.9/site-packages/aiohttp/client_reqrep.py", line 1119, in json
return loads(stripped.decode(encoding))
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xff in position 72: invalid start byte
