I’ve experienced this several times when I’m trying to fine tune my sensors (which afaik can’t be reloaded without reloading all of HomeAssistant)
The symptom is suddenly I can’t restart thru the web-GUI even though I pass the validation check. When I check the logs, it has something like this every time:
20-02-23 16:28:40 INFO (SyncWorker_7) [hassio.docker.interface] Restart homeassistant/intel-nuc-homeassistant
20-02-23 16:38:50 WARNING (MainThread) [hassio.homeassistant] Don't wait anymore of Home Assistant startup!
20-02-23 16:38:50 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished coro=<process_lock.<locals>.wrap_api() done, defined at /usr/src/hassio/hassio/utils/__init__.py:20> exception=HomeAssistantError()>
File "/usr/src/hassio/hassio/utils/__init__.py", line 29, in wrap_api
return await method(api, *args, **kwargs)
File "/usr/src/hassio/hassio/homeassistant.py", line 381, in restart
await self._block_till_run()
File "/usr/src/hassio/hassio/homeassistant.py", line 588, in _block_till_run
raise HomeAssistantError()
hassio.exceptions.HomeAssistantError
20-02-23 16:40:39 INFO (SyncWorker_6) [hassio.docker.interface] Restart homeassistant/intel-nuc-homeassistant
20-02-23 16:48:23 ERROR (MainThread) [hassio.utils] Can't execute restart while a task is in progress
Host system
Hostname | hassio |
System | HassOS 3.11 |
Deployment | production |
Supervisor
Version | 201 |
Latest version | 201 |
If I try to reload via command line, it hangs at “Processing” forever.
At this point, the only solution I can find to move forward is power cycle/full reboot the whole host.
Anyone know anything about this?
