Yes, leaving mariadb_url: 'mysql://homeassistant:password@core-mariadb/homeassistant?charset=utf8mb4'remaining in secrets.yaml. Otherwise HA wouldn’t restart… When I comment out this line again after rebooting I just get the same error.
Don’t use the one in the UI, use the config check via SSH and restart that way. When you remove yaml configurations, you may get errors via the UI one.
Exactly like that, but when I used secrets.yaml it didn’t work (have worked before).
I solved it by moving the db_url outside the secrets.yaml and into configuration.yaml.
Rebooted
Uninstalled maria db add-on
Commented out as above
and voilá!
Maria db is gone and stock recorder took over.
Thank you for taking your time, really appreciate the support
