I’ve successfully paired 6 Ecolink motion sensors, however on the 7th one, I had problems pairing. It shows up on the Zwave manager but it doesn’t work. I tried every method to get it unpaired. The unpairing process for the Ecolink sensors is fairly easy. Take the battery out for 5 minutes and put it back in. I’ve successfully unpair multiple times, but I’m having trouble with this one.
Steps I’ve taken
1 remove node using Z-Wave Network Management.
2 “remove failed node” and “replace failed node” (Status is showing as Sleeping and not Dead)
3 Removed the Aeotec Z-Stick put it on exclusion mode and tried unpairing
4. Removed battery from Sensor and restarted HA in hopes of getting the Dead status
Nothing I’ve done worked, can anyone help me get back on track? Thanks in advance…
I have a Smartthing lying around so I tried to find the Ecolink sensor, sure enough I was able to find the sensor and pair it to Smartthings So the problem is that HA thinks that the sensor is still paired, can’t find any options to remove it from HA. Any help?
Here’s the log for the problematic sensor Node 13
2017-08-14 00:15:44.604 Detail, Node013, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2017-08-14 00:15:44.605 Detail, Node013, QueryStage_ProtocolInfo
2017-08-14 00:15:44.605 Detail, Node013, Queuing (Query) Get Node Protocol Info (Node=13): 0x01, 0x04, 0x00, 0x41, 0x0d, 0xb7
2017-08-14 00:15:44.605 Detail, Node013, Queuing (Query) Query Stage Complete (ProtocolInfo)
2017-08-14 00:15:44.605 Info, Node013, Initializing Node. New Node: false (false)
2017-08-14 00:16:14.827 Detail, Node013, ZW_SEND_DATA Request with callback ID 0x15 received (expected 0x15)
2017-08-14 00:16:14.827 Info, Node013, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2017-08-14 00:16:14.827 Info, Node013, Node 13 has been marked as asleep
2017-08-14 00:16:14.827 Info, Node013, Node not responding - moving QueryStageComplete command to Wake-Up queue
2017-08-14 00:16:14.827 Detail, Node013, Notification: Notification - NoOperation
2017-08-14 00:16:14.827 Info, Notification: Notification home d774e0e1 node 13 No Operation Message Complete
2017-08-14 00:16:14.827 Detail, Node013, Notification: Notification - Node Asleep
