Whenever I try to reboot I get this error:
Logger: homeassistant.components.websocket_api.http.connection
Source: helpers/config_validation.py:766
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 9:08:11 (2 occurrences)
Last logged: 9:11:00
[547962872064] string indices must be integers
[547962648608] string indices must be integers
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 185, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1492, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1527, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 549, in async_handle_core_service
errors = await conf_util.async_check_ha_config_file(hass)
File "/usr/src/homeassistant/homeassistant/config.py", line 942, in async_check_ha_config_file
res = await check_config.async_check_ha_config_file(hass)
File "/usr/src/homeassistant/homeassistant/helpers/check_config.py", line 225, in async_check_ha_config_file
p_validated = platform_schema(p_validated)
File "/usr/local/lib/python3.9/site-packages/voluptuous/validators.py", line 218, in __call__
return self._exec((Schema(val) for val in self.validators), v)
File "/usr/local/lib/python3.9/site-packages/voluptuous/validators.py", line 337, in _exec
v = func(v)
File "/usr/local/lib/python3.9/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.9/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
return schema(data)
File "/usr/local/lib/python3.9/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.9/site-packages/voluptuous/schema_builder.py", line 386, in validate_mapping
cval = cvalue(key_path, value)
return schema(data)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 489, in verify
return cast(dict, schema(value))
File "/usr/local/lib/python3.9/site-packages/voluptuous/validators.py", line 215, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.9/site-packages/voluptuous/validators.py", line 339, in _exec
v = func(path, v)
return schema(data)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 766, in validator
value = config[key]
TypeError: string indices must be integers
Maybe this is also relevant: I’m also getting a similar error when I’m trying to check my config.yaml
Logger: aiohttp.server
First occurred: 8:58:48 (2 occurrences)
Last logged: 9:37:11
Error handling request
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 89, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 24, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 78, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 144, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 135, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/core.py", line 29, in post
errors = await async_check_ha_config_file(request.app["hass"])
v = func(v)
return schema(data)
return schema(data)
v = func(path, v)
return schema(data)
value = config[key]
Can anybody help me out please?
