Can't restart HA
Failed to call service homeassistant/restart. The system cannot restart while a database upgrade is in progress.
I’m getting this warning every time I try and restart home assistant, thing is it’s been like this since yesterday morning when I upgraded to 2021.9.3 from 2021.8.x
I would have thought 24 hours was enough time to upgrade the DB?
I would think that would be done unless your db is really large and the machine is slow (Rpi3?).
If you get tired of waiting and don’t mind losing data (worst case is whatever data is within the purge days setting) then you could stop HA and delete the db (or better rename it to something else - xxx.db.old) then start HA. It will then create an empty db
