Can't restart Home Assistant, argument of type 'NoneType' is not iterable
Hi, I’m trying to restart my Home Assistant fora few days and I’m not able to do it, this error appears in the log
Logger: homeassistant.components.websocket_api.http.connection
Source: components/scene/__init__.py:28
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 09:25:50 (2 occurrences)
Last logged: 09:27:11
[139781323648352] argument of type 'NoneType' is not iterable
[139781197654816] argument of type 'NoneType' is not iterable
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 189, in handle_call_service
    await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1627, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1664, in _execute_service
    await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
  File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 665, in async_handle_core_service
    errors = await conf_util.async_check_ha_config_file(hass)
  File "/usr/src/homeassistant/homeassistant/config.py", line 928, in async_check_ha_config_file
    res = await check_config.async_check_ha_config_file(hass)
  File "/usr/src/homeassistant/homeassistant/helpers/check_config.py", line 201, in async_check_ha_config_file
    p_validated = component_platform_schema(p_config)
  File "/usr/local/lib/python3.9/site-packages/voluptuous/schema_builder.py", line 272, in __call__
    return self._compiled([], data)
  File "/usr/local/lib/python3.9/site-packages/voluptuous/validators.py", line 229, in _run
    return self._exec(self._compiled, value, path)
  File "/usr/local/lib/python3.9/site-packages/voluptuous/validators.py", line 353, in _exec
    v = func(path, v)
  File "/usr/local/lib/python3.9/site-packages/voluptuous/schema_builder.py", line 818, in validate_callable
    return schema(data)
  File "/usr/src/homeassistant/homeassistant/components/scene/__init__.py", line 28, in _hass_domain_validator
    if CONF_PLATFORM not in config:
TypeError: argument of type 'NoneType' is not iterable
I tried to recover from the last three backups that are available but same happens. I tried also to check the config files in YAML menu but it get stucked on the loading sign. I don’t know what else to try :frowning:
Is this always caused by a problem with scenes?
I am getting the same error, but I can’t see anything to do with scenes being the problem. Here is my YAML in case you can help?
Source: components/websocket_api/commands.py:241
integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 2:42:53 AM (3 occurrences)
Last logged: 2:47:28 AM
[139860690087232] Unexpected exception
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 241, in handle_call_service
    response = await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 2763, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2806, in _execute_service
    return await target(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1102, in _async_admin_handler
    await result
  File "/usr/src/homeassistant/homeassistant/components/homeassistant/__init__.py", line 190, in async_handle_core_service
  File "/usr/src/homeassistant/homeassistant/config.py", line 1687, in async_check_ha_config_file
  File "/usr/src/homeassistant/homeassistant/helpers/check_config.py", line 298, in async_check_ha_config_file
    p_validated = platform_schema(p_validated)
  File "/usr/local/lib/python3.12/site-packages/voluptuous/validators.py", line 259, in __call__
    return self._exec((Schema(val) for val in self.validators), v)
  File "/usr/local/lib/python3.12/site-packages/voluptuous/validators.py", line 382, in _exec
    v = func(v)
  File "/usr/local/lib/python3.12/site-packages/voluptuous/schema_builder.py", line 205, in __call__
  File "/usr/local/lib/python3.12/site-packages/voluptuous/schema_builder.py", line 779, in validate_callable
    return schema(data)
  File "/usr/local/lib/python3.12/site-packages/voluptuous/schema_builder.py", line 549, in validate_dict
    return base_validate(path, data.items(), out)
  File "/usr/local/lib/python3.12/site-packages/voluptuous/schema_builder.py", line 330, in validate_mapping
    cval = cvalue(key_path, value)
    return schema(data)
  File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 604, in verify
    return cast(dict, schema(value))
  File "/usr/local/lib/python3.12/site-packages/voluptuous/validators.py", line 256, in _run
  File "/usr/local/lib/python3.12/site-packages/voluptuous/validators.py", line 384, in _exec
    v = func(path, v)
    return schema(data)
  File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 889, in validator
    if key in config:
have you solved it?
DUCKING misssing indention
