Can't restart Home Assistant due to "Integration not found" error
I’m completely new to HA and I’ve run into a problem. I couldn’t get my automations to work so I decided that I’d try to restart HA and see if that could help. When I tried to restart I got an error message and checked the log that contained the following errors. I’d really appreciate suggestions on how to untangle this.
Thanks in advance.
2022-12-23 19:58:31.055 ERROR (MainThread) [homeassistant.setup] Setup failed for mode: Integration not found.
2022-12-23 19:58:31.079 ERROR (MainThread) [homeassistant.setup] Setup failed for action: Integration not found.
2022-12-23 19:58:31.084 ERROR (MainThread) [homeassistant.setup] Setup failed for trigger: Integration not found.
2022-12-23 19:58:31.086 ERROR (MainThread) [homeassistant.setup] Setup failed for alias: Integration not found.
2022-12-23 19:58:31.088 ERROR (MainThread) [homeassistant.setup] Setup failed for condition: Integration not found.
2022-12-23 22:35:08.924 ERROR (MainThread) [homeassistant.components.hassio] The system cannot restart because the configuration is not valid: Integration error: action - Integration 'action' not found.
Integration error: alias - Integration 'alias' not found.
Integration error: mode - Integration 'mode' not found.
Integration error: condition - Integration 'condition' not found.
Integration error: trigger - Integration 'trigger' not found.
2022-12-23 22:35:08.937 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [547852562112] The system cannot restart because the configuration is not valid: Integration error: action - Integration 'action' not found.
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 200, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1745, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1782, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 529, in async_handle_core_service
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: The system cannot restart because the configuration is not valid: Integration error: action - Integration 'action' not found.
Delete ur “automation” restart HA, start over and make sure your “Automation” works, with correct syntax etc.
Thanks for the tip. I’ve now deleted the two latest automations but in the “Check and restart” under Developer Tools I still get the following errors:
Any ideas?
ok, well i don’t know what you have done, so hard to tell/advice … check your configuration.yaml, try “commend-out” automations there, then they will not be included during restart/startup, go through your automation.yaml-file, and if there’s something else in configuration.yaml that seems “wrong” commend-out this aswell
Thanks again. I just started with HA so I only have 3-4 automations. That should be pretty easy.
There could be another source of the problem, though. I installed a new smart socket earlier today. To begin with my router assigned it a random ip-address through DCGP. I changed the ip to a reserved address which I do with all my devices. In HA, however, it was registered with the wrong ip-address. I discovered this during the add new device process and restarted my RasPi to get HA to recognized the correct ip-address. It worked with respect to the ip-address but I was wondering if the restart during the add device process could have something to do with it?
ALL the errors is related to an automation … anyway, if you change the ip of a device in your router, i suggest you restart that device, and where ever HA registered ( in which integration ) there will still be an entry for this (old)ip , but i guess you can live with this for awhile, as you say, your new to HA, my advice is to not “pace ahead”, Your Router is your “heart” for IP device, make the changes there( name/reservations etc ), before you add those devices to HA
Hi guys also cannot restart it via quick restart, ok with full restart .
It say integration “c” not found. Sometimes it say intergation I “ not found
Any ideas where to start digging?
Logger: homeassistant.components.websocket_api.http.connection
Source: loader.py:879
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 20:11:42 (1 occurrences)
Last logged: 20:11:42
[139823759047888] Integration ‘c’ not found.
File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 205, in handle_call_service
File “/usr/src/homeassistant/homeassistant/core.py”, line 1957, in async_call
response_data = await coro
File “/usr/src/homeassistant/homeassistant/core.py”, line 1997, in _execute_service
return await cast(
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 927, in admin_handler
await result
File “/usr/src/homeassistant/homeassistant/components/homeassistant/init.py”, line 339, in async_handle_reload_all
await asyncio.gather(*tasks)
return await cast(
await result
File “/usr/src/homeassistant/homeassistant/helpers/reload.py”, line 176, in _reload_config
await async_reload_integration_platforms(hass, domain, platforms)
File “/usr/src/homeassistant/homeassistant/helpers/reload.py”, line 53, in async_reload_integration_platforms
File “/usr/src/homeassistant/homeassistant/helpers/reload.py”, line 63, in _resetup_platform
integration = await async_get_integration(hass, integration_platform)
File “/usr/src/homeassistant/homeassistant/loader.py”, line 879, in async_get_integration
raise int_or_exc
homeassistant.loader.IntegrationNotFound: Integration ‘c’ not found.
Would be a help if you listed/looked at/towards the integrations you have installed yourself , if you want more relevant log-info, enable Debug in Logger
In config.yaml(which btw also would be a good point to look over, if you have manually added something there.)
ADD:
“logger default debug” (temporary!)
I just had a bunch of “Integration ‘c’ not found” and “Integration ‘i‘ not found”.
All is clear after removing “Programmable Thermostat” from my HACS.
I wasn’t using it anyway.
