When I try to restart Home assistant I’m getting the following error
2020-02-01 21:23:31 ERROR (MainThread) [homeassistant.components.hassio] Invalid config for [switch.mqtt]: [brightness_command_topic] is an invalid option for [switch.mqtt]. Check: switch.mqtt->brightness_command_topic. (See ?, line ?).
Notice the question marks in see and line which makes it practically impossible to track down where this is actually happening.
To make things worse my configuration.yaml doesn’t have any MQTT switches
My configuration.yaml is as follows
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
# Sensors
- platform: london_underground
line:
- London Overground
- Northern
- platform: sonarr
api_key: de705ecd51be4b1fa1fabb4595c9db33
host: 192.168.0.15
monitored_conditions:
- upcoming
days: 2
- platform: waqi
token: xxxx
locations:
- london
- platform: sonarr_upcoming_media
api_key: xxxx
host: 192.168.0.15
port: 8989
days: 7
max: 10
- platform: qbittorrent
url: 'http://192.168.0.15:9091'
username: camy
password: camy
- platform: dht
sensor: DHT11
pin: 4
- temperature
- humidity
- platform: moon
#Weather
weather:
- platform: darksky
api_key: xxxx
#Discovery
discovery:
#Media Players
media_player:
- platform: kodi
host: 192.168.0.15
username: xxxx
password: xxxx
#Switches
switch:
- platform: broadlink
host: 192.168.0.20
mac: '78:0F:77:00:03:75'
switches:
tv:
friendly_name: "TV"
command_on: 'JgCMAE8UKBMUFCgUExQpExMUFBQnFBQUFBMUFBQAA1FPFCkTExQoFBMUKBQUExQUKBMUFBQTFBQUAANSTxQoExQUJxQUFCcUFBQTFCgUFBMVExQTFQADUlATKBQUEygUFBMpExQTFBQoExQUFBQTFBQAA1NPFCgUExQoFBMUKBQUExQUKBMUFBQUExQUAA0FAAAAAAAAAAAAAAAA'
command_off: 'JgCMAE8UKBMUFCgUExQpExMUFBQnFBQUFBMUFBQAA1FPFCkTExQoFBMUKBQUExQUKBMUFBQTFBQUAANSTxQoExQUJxQUFCcUFBQTFCgUFBMVExQTFQADUlATKBQUEygUFBMpExQTFBQoExQUFBQTFBQAA1NPFCgUExQoFBMUKBQUExQUKBMUFBQUExQUAA0FAAAAAAAAAAAAAAAA'
fan:
friendly_name: "Air Cooler"
command_on: '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'
command_off: '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'
#Lights
- platform: mqtt
command_topic: "wled/28e8e4"
brightness_command_topic: "wled/28e8e4"
rgb_command_topic: "wled/28e8e4/col"
rgb_command_template: "{{ '#%02x%02x%02x' | format(red, green, blue)}}"
effect_command_topic : "wled/28e8e4/api"
effect_list:
- "[FX=00] Solid"
- "[FX=01] Blink"
- "[FX=02] Breathe"
- "[FX=03] Wipe"
- "[FX=04] Wipe Random"
- "[FX=05] Random Colors"
- "[FX=06] Sweep"
- "[FX=07] Dynamic"
- "[FX=08] Colorloop"
- "[FX=09] Rainbow"
- "[FX=10] Scan"
- "[FX=11] Dual Scan"
- "[FX=12] Fade"
- "[FX=13] Chase"
- "[FX=14] Chase Rainbow"
- "[FX=15] Running"
- "[FX=16] Saw"
- "[FX=17] Twinkle"
- "[FX=18] Dissolve"
- "[FX=19] Dissolve Rnd"
- "[FX=20] Sparkle"
- "[FX=21] Dark Sparkle"
- "[FX=22] Sparkle+"
- "[FX=23] Strobe"
- "[FX=24] Strobe Rainbow"
- "[FX=25] Mega Strobe"
- "[FX=26] Blink Rainbow"
- "[FX=27] Android"
- "[FX=28] Chase"
- "[FX=29] Chase Random"
- "[FX=30] Chase Rainbow"
- "[FX=31] Chase Flash"
- "[FX=32] Chase Flash Rnd"
- "[FX=33] Rainbow Runner"
- "[FX=34] Colorful"
- "[FX=35] Traffic Light"
- "[FX=36] Sweep Random"
- "[FX=37] Running 2"
- "[FX=38] Red & Blue"
- "[FX=39] Stream"
- "[FX=40] Scanner"
- "[FX=41] Lighthouse"
- "[FX=42] Fireworks"
- "[FX=43] Rain"
- "[FX=44] Merry Christmas"
- "[FX=45] Fire Flicker"
- "[FX=46] Gradient"
- "[FX=47] Loading"
- "[FX=48] In Out"
- "[FX=49] In In"
- "[FX=50] Out Out"
- "[FX=51] Out In"
- "[FX=52] Circus"
- "[FX=53] Halloween"
- "[FX=54] Tri Chase"
- "[FX=55] Tri Wipe"
- "[FX=56] Tri Fade"
- "[FX=57] Lightning"
- "[FX=58] ICU"
- "[FX=59] Multi Comet"
- "[FX=60] Dual Scanner"
- "[FX=61] Stream 2"
- "[FX=62] Oscillate"
- "[FX=63] Pride 2015"
- "[FX=64] Juggle"
- "[FX=65] Palette"
- "[FX=66] Fire 2012"
- "[FX=67] Colorwaves"
- "[FX=68] BPM"
- "[FX=69] Fill Noise"
- "[FX=70] Noise 1"
- "[FX=71] Noise 2"
- "[FX=72] Noise 3"
- "[FX=73] Noise 4"
- "[FX=74] Colortwinkle"
- "[FX=75] Lake"
- "[FX=76] Meteor"
- "[FX=77] Smooth Meteor"
- "[FX=78] Railway"
- "[FX=79] Ripple"
- "[FX=80] Twinklefox"
- "[FX=81] Twinklecat"
- "[FX=82] Halloween Eyes"
input_select:
wled_presets:
options:
- "[PL=01] Preset 1"
- "[PL=02] Preset 2"
- "[PL=03] Preset 3"
- "[PL=04] Preset 4"
- "[PL=05] Preset 5"
- "[PL=06] Preset 6"
- "[PL=07] Preset 7"
- "[PL=08] Preset 8"
- "[PL=09] Preset 9"
- "[PL=10] Preset 10"
- "[PL=11] Preset 11"
- "[PL=12] Preset 12"
- "[PL=13] Preset 13"
- "[PL=14] Preset 14"
- "[PL=15] Preset 15"
- "[PL=16] Preset 16"
wled_palette_list:
options:
- "[FP=00] Default"
- "[FP=01] Random Cycle"
- "[FP=02] Primary color"
- "[FP=03] Based on primary"
- "[FP=04] Set colors"
- "[FP=05] Based on set"
- "[FP=06] Party"
- "[FP=07] Cloud"
- "[FP=08] Lava"
- "[FP=09] Ocean"
- "[FP=10] Forest"
- "[FP=11] Rainbow"
- "[FP=12] Rainbow bands"
- "[FP=13] Sunset"
- "[FP=14] Rivendell"
- "[FP=15] Breeze"
- "[FP=16] Red & Blue"
- "[FP=17] Yellowout"
- "[FP=18] Analoguous"
- "[FP=19] Splash"
- "[FP=20] Pastel"
- "[FP=21] Sunset 2"
- "[FP=22] Beech"
- "[FP=23] Vintage"
- "[FP=24] Departure"
- "[FP=25] Landscape"
- "[FP=26] Beach"
- "[FP=27] Sherbet"
- "[FP=28] Hult"
- "[FP=29] Hult 64"
- "[FP=30] Drywet"
- "[FP=31] Jul"
- "[FP=32] Grintage"
- "[FP=33] Rewhi"
- "[FP=34] Tertiary"
- "[FP=35] Fire"
- "[FP=36] Icefire"
- "[FP=37] Cyane"
- "[FP=38] Light Pink"
- "[FP=39] Autumn"
- "[FP=40] Magenta"
- "[FP=41] Magred"
- "[FP=42] Yelmag"
- "[FP=43] Yelblu"
- "[FP=44] Orange & Teal"
- "[FP=45] Tiamat"
- "[FP=46] April Night"
- "[FP=47] Orangery"
- "[FP=48] C9"
- "[FP=49] Sakura"
input_number:
ledspeed:
initial: 0
min: 0
max: 255
step: 1
ledintensity:
initial: 0
min: 0
max: 255
step: 1
And my automation look like
- id: wled_speed
alias: wled_speed
- entity_id: input_number.ledspeed
platform: state
condition: []
- data_template:
topic: wled/28e8e4/api
payload: SX={{ states('input_number.ledspeed') | int }}
service: mqtt.publish
- id: wled_intensity
alias: wled_intensity
- entity_id: input_number.ledintensity
platform: state
condition: []
- data_template:
payload: IX={{ states('input_number.ledintensity') | int }}
- id: wled_palette
alias: WLED Palette
- platform: state
entity_id: input_select.wled_palette_list
condition: []
- service: mqtt.publish
data_template:
payload: "{{ states('input_select.wled_palette_list') }}"
- id: wled_presets
alias: WLED Presets
- platform: state
entity_id: input_select.wled_presets
condition: []
data_template:
payload: "{{ states('input_select.wled_presets') }}"
- alias: MiLight Forwarder
initial_state: True
platform: mqtt
topic: milight/updates/0x1A75/rgb_cct/+
data_template:
topic: "milight/commands/0x1B75/rgb_cct/{{ trigger.topic.split('/')[4] }}"
payload_template: >
{{ trigger.payload }}
Any help would be much appreciated as I’ve finally got things setup and working if it nukes itself now I might cry
