Can't restart Home Assistant
Tried to restart the server a couple of times but i’m getting this error:
Logger: homeassistant.core
Source: components/google_translate/tts.py:5
First occurred: 19:55:07 (3 occurrences)
Last logged: 20:03:55
Error executing service: <ServiceCall homeassistant.restart (c:a11da699dbb20082927510a3757e16d2)>
Error executing service: <ServiceCall homeassistant.restart (c:347c79babdbc020a94452cc4d800b151)>
Error executing service: <ServiceCall homeassistant.restart (c:550d005df1460190ea6c54a7b9d26f69)>
  File "/usr/src/homeassistant/homeassistant/core.py", line 1496, in catch_exceptions
    await coro_or_task
  File "/usr/src/homeassistant/homeassistant/core.py", line 1515, in _execute_service
    await handler.job.target(service_call)
  File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 481, in async_handle_core_service
    errors = await conf_util.async_check_ha_config_file(hass)
  File "/usr/src/homeassistant/homeassistant/config.py", line 898, in async_check_ha_config_file
    res = await check_config.async_check_ha_config_file(hass)
  File "/usr/src/homeassistant/homeassistant/helpers/check_config.py", line 210, in async_check_ha_config_file
    platform = p_integration.get_platform(domain)
  File "/usr/src/homeassistant/homeassistant/loader.py", line 485, in get_platform
    cache[full_name] = self._import_platform(platform_name)
  File "/usr/src/homeassistant/homeassistant/loader.py", line 490, in _import_platform
    return importlib.import_module(f"{self.pkg_path}.{platform_name}")
  File "/usr/local/lib/python3.8/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
  File "<frozen importlib._bootstrap>", line 991, in _find_and_load
  File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 783, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "/usr/src/homeassistant/homeassistant/components/google_translate/tts.py", line 5, in <module>
    from gtts import gTTS, gTTSError
  File "/usr/local/lib/python3.8/site-packages/gtts/__init__.py", line 3, in <module>
    from .tts import gTTS, gTTSError
  File "<frozen importlib._bootstrap_external>", line 779, in exec_module
  File "<frozen importlib._bootstrap_external>", line 911, in get_code
  File "<frozen importlib._bootstrap_external>", line 580, in _compile_bytecode
ValueError: bad marshal data (unknown type code)
Any idea what i can do?
What did you do before the restart?
A search for that error in the issue tracker shows results where reinstall of the last update fixes this.
Don’t know what i did, made a change in my config, because of that i wanted to restart. Gone have a look!
